Old 08-11-2009, 12:35 PM   #1
DVD Player 21SS ROO
I just recently purchased a 2010 21ss ROO. We've only taken it out once. I purchased a flat screen tv. I brought movies and a coax cable to hook the tv to the dvd player. When I got around to hooking it up, I didn't have the right connection. Any ideas on what I may need to buy to get this working?
http://www.ohiovalleycampers.com
Ohio Valley Camper is offline   Reply With Quote
Old 08-11-2009, 01:30 PM   #2
KyDan's Avatar
Typically a DVD player to TV setup requires something like this--
http://www.sfcable.com/cable/p/254-603IV.html
They can be bought together like the picture above or separately
where you'll get one that's 3 cables called a component cable
and one that's 2 cables called audio cable.
Walmart, RadioShack, Target, and almost any store that sells
TVs and electronics will have cables for this.
Don't spend a lot of cash.
Those monster cables with gold plated ends that cost $30 on up
are not necessary.
Good luck!
Peace!
Dan & Rita D
Blue Ox WD hitch
KyDan is online now   Reply With Quote
Old 08-11-2009, 02:23 PM   #3
are not necessary.
Good luck!
Thanks, but the I have the Wall plate with just on gold connector. I don't have the 3 component connectors. Is there a single cord that will run from the outlet/wall plate to the tv?
Let me know if you can help.
Old 08-11-2009, 04:34 PM   #4
KyDan's Avatar
Then virtually any cable with "RCA" plugs on each end
will work.
It can be a 2 way stereo audio cable or a 3 way component
cable or anything you've got laying around left over from
that DVD player or game console at home.
Just use one of the wires to run from your Trailer DVD
player (Concertone??) to the "video input" on the back
or side of your new TV.
The TV will not have sound.
The Concertone will provide sound thru the speakers
in the trailer.
You can leave the TV sound turned all the way down.
You will use the TV speakers when you are watching
broadcast TV stations.
Hope this helps!
KyDan
Peace!
Dan & Rita D
Blue Ox WD hitch
Old 08-11-2009, 06:42 PM   #5
I also had the same problem, there was a blank plate to the left of the
cable jack, ran the three wires fromthe concertone to the wall plate
and from the plate to the tv and it worked just fine.
will post pictures when i figure out how
fdcobra93 is offline   Reply With Quote
Old 08-12-2009, 10:06 AM   #6
So, do I need to take the plate off? Or just get the audio cable. If it's just an audio cable, how doest the dvd (which I believe to be concertone) play the movie on the tv. Sorry, my electrical skills don't travel very far. thanks for the help.
Old 08-12-2009, 12:25 PM   #7
KyDan's Avatar
I believe I've answered your question.
Here we go again.....
You said---
Thanks, but the I have the Wall plate with just on[e] gold connector. I don't have the 3 component connectors. Is there a single cord that will run from the outlet/wall plate to the tv?
And I said----
will work.
Just use one of the wires to run from your (Concertone??) to the "video input" on the back or side of your new TV.
in the trailer.
Put a DVD in the concertone.
Turn on the TV and hit the "input" button on the TV remote.
Choose input 1 or something.....
Turn UP the volume on the concertone.
Be sure your outside speakers are not on if you have
them.
One wire is all you need to get the picture (video) from the concertone
to the TV.
Old 08-12-2009, 12:48 PM   #8
Got it. That's what I was looking for.
Old 08-27-2009, 07:07 AM   #9
EastlakeRoo's Avatar
Just hooked my Concertone up to my TV last night to run the DVD Player. You are correct in these statements:
The Concertone will provide sound thru the speakers in the trailer.
One Wire is all that is needed to run the DVD Player. Now I don't need to lug around a seperate DVD Player for my son to watch his DVD's. We can utilize the CONCERTONE which was already in the trailer when we got it.
2014 Wildwood 300BH
2014 Ford Explorer XLT
2011 Ford F350 FX4
Eastlake, OH
EastlakeRoo is offline   Reply With Quote
