08-02-2016, 11:44 PM
DVD question
We are supposed to be able to play a DVD through our TV (this is the pre-installed DVD player that came with our camper) using the 3 cables that come out of the wall into our television. However, our television says it can't find any signal for the DVD player. We get sound out of the speakers but NO VIDEO! I checked the connections behind the wall on all 3 cables and they seem to be fine. I don't know what else to do to troubleshoot why the video portion is not recognized by my Smart Television. Ya'll helped me so much with my water heater problem, I thought I would try one more problem on you.
08-03-2016, 12:42 AM
1 did you check the connection at the dvd player end
2 are you on the correct input for the tv
mine was disconnected behind the roof plate but just the yellow cord
08-03-2016, 12:48 AM
Hi the TV source is set for the cable that is inputting the signal from the DVD player ? Is the sound coming from the DVD/trailer speakers?
08-03-2016, 04:14 AM
Troubleshooting is a PAIN!
-Is there a DVD button on the stereo? Maybe it thinks it's playing an audio cd.
-hookup your home DVD player to the tv to verify that the problem isn't with the tv. I wouldn't bother with audio connections because you said that you have sound. If that works now the pain begins!
-Pull out the stereo and hook up a different video cable directly from the stereo to the tv. If this works you have a bad cable. If it doesn't work you have a bad stereo.
Or just take it to your dealer. . Rv's don't have the best stereos!
04 Ram 3500
07 Ram 3500 X2
10 Ram 3500 Laramie
2011 Puma 295kbh
08-03-2016, 10:45 AM
Had an HDMI cable connected to mine that went bad. Had to pull out the dvd unit and hook up and run a new cable.
It went bad because of me, not the trailers fault on this one.
Dwayne and Susan
Jiro and Phoebe-4 legged family members
Mike and Dana - Traveling buddies
2016 Ford F350 XLT 6.7 Powerstroke DRW 4X4
2016 Brookstone 395RL
08-03-2016, 11:06 AM
Haven't checked connection at DVD end yet. somewhat scared of breaking something trying to get it off the wall. But, I think that is exactly what I have to do. Thanks.
08-03-2016, 11:08 AM
I haven't thought about the DVD button exactly that way. I might actually have that and I haven't seen it on the machine. The sound is coming through the house speakers so I would think that the machine recognizes that it is a DVD. But, a little more troubleshooting will be necessary. Thanks for the reply.
08-03-2016, 11:21 AM
I'm open to how to get the DVD off the wall if you can tell me that.
08-03-2016, 11:31 AM
What model? If an iRV radio, remove two plastic side plates with small flathead screwdriver, then you will see the screws. Not too difficult getting it out.
2016 Roo 21SS
2005 Ford Excursion-Sherman
Mods so far:
PI hardwired EMC, Wire Shelving in wardrobe
Plexiglass screen door protector, Blue LED Wine nook
stairs, and counting...
08-03-2016, 11:40 AM
I would actually have to arise from the comfort of my easy chair to go and look to see what model it is. Isn't that sad? However, it looks like it has a plastic face plate around the edge and I will find those screws you are talking about. I'm afraid of breaking the plastic because usually I go into things like a bull in a china cabinet. Perhaps I can have a little more finesse with the thing and not break it. Thanks for the help and encouragement!
08-03-2016, 11:57 AM
Look for tabs, those are the ones you want to press in with the screwdriver.
2016 Roo 21SS
Mods so far:
08-26-2016, 12:29 AM
2017 Salem 30KQBSS
Better late than never...
You probably already got this figured out since this has been posted a while, but just in case you didn't here's another possibility (I just spent 3 hours tonight getting this figured out).
If Forest River uses a consistent set up, next to your DVD player will be two outlet jacks: one plate with 2 coaxial cable jacks (TV and Aux/Satellite) and another plate with a standard RCA jack setup with one red, one white and one yellow RCA jack.
The RCA jacks are old-school, and most new hi-def TV's don't use them anymore (the new one I just bought didn't). Most TV's now have a coaxial input, an HDMI input, and a ColorStream composite input (red, blue, green jacks). In order to work around this, plug a single RCA cable into the YELLOW jack on the wall plate next to the DVD. Then plug that cable into the GREEN jack on your TV. Then set your TV source to Video or Composite, or whatever lines up with the ColorStream input (may have to check your TV manual, or just cycle through sources on your TV while you are playing a DVD).
That should get you a video signal on your TV, while the sound plays through the camper speakers. It won't be high def, but that's because the factory DVD player is old-school.
Hope that helps, assuming you haven't already figured it out.
