Old 12-13-2018, 08:44 PM   #1
Earthquake Damage Assessment
Hi all - we have a 2014 Sunseeker 2450 here in Southcentral Alaska. It's nicely tucked in for the winter under its overhang - winterized, slide-outs in, and leveled on the Bigfoot levellers (on chocks). It's not fully off the ground, but the weight's off the tires. Batteries removed and stored in the garage.
We were fortunate that we didn't have any (major) damage from the recent earthquake (7.0) to our house or garage. Lots of busted glasses and "stuff" which fell - and some scary moments getting bounced around - but no damage to our foundation, structure or water/gas pipes (thankfully). We prepare for these things, and had the generator going for 12 hours until the power came back on. [The iconic road damage was a few miles away, but that was caused by ground failure in what's essentially a road built on a bog].
We checked out the inside of the Sunseeker and found the (expected) drawers flung open and kitchen "stuff" had fallen out of closets. Damp-rid spilled out of its container, but other than that, couldn't see any damage. (Levellers are all solid - no evidence of any leaks/torque or movement). I'm sure once I de-winterize I could find a new water leak somewhere, but wonder what, if any, other damage I should look for? Thanks in advance for any ideas...and Happy Solstice
chumis is offline   Reply With Quote
Old 12-13-2018, 09:14 PM   #2
It's just a matter of time here in SoCal. Haven't had a significant quake for the last 15+ years. Glad you were mostly unscathed.
2018 DX3 37TS Sunset
2019 Rubicon JLU
2022 RZR Pro 4 Ultimate
rskeans is offline   Reply With Quote
Old 12-13-2018, 09:17 PM   #3
geezer with gadgets
757Dave's Avatar
I would get the propane gas lines checked out just to be sure there were no leaks.
Glad you are OK after that big scare.
Happy travels...
Sent from my Atari 2600
2011 Sunseeker 3170ds "Ladybug"
2017 Jeep Grand Cherokee TOAD
Days camped 2015: 37; 2016: 66; 2017: 86 2018: 57 2019: 30
757Dave is offline   Reply With Quote
Old 12-13-2018, 09:44 PM   #4
Thanks for the propane line check idea...much appreciated!
Old 12-13-2018, 09:51 PM   #5
I plan on going next year, I hope the roads are fixed by then
spock123 is offline   Reply With Quote
Old 12-13-2018, 10:01 PM   #6
Coach
I would guess a camper riding out an earthquake wouldn't be much different than riding down a rough road too fast. Check out your suspension since your tires were still on the ground. Propane lines as others stated. Probably can't test for a while, but drain pipes should probably checked too.
Cut it 3 times and it's still too short...
2017 Sandpiper 381RBOK
2006 Ram 3500 Cummins Dually
valleyduo is offline   Reply With Quote
Old 12-14-2018, 12:25 AM   #7
Most of the road damage was fixed (quickly, if temporarily). Most everything should be "good to go" by next summer, so hope you have a great trip!
https://www.ktuu.com/content/news/DO...502737871.html
Old 12-14-2018, 06:29 AM   #8
Citrus County, Fl.
GL1800Rider's Avatar
I would also have the roof inspected/re-sealed as it does not take much to develop a leak, especially at the front corners over the cab and the rear.
2016 Forester 3011DS
2017 Toyota Corolla SE toad
99 Terry 31G
GL1800Rider is offline   Reply With Quote
Old 12-14-2018, 11:28 AM   #9
Very good advice on the roof check - thanks!
