Old 10-30-2014, 08:12 AM   #1
beeman's Avatar
Electric stabilizer jacks? ? ? ?
What is the general consensus on electric stabilizer jacks on a travel trailer? Heard a lot of people complaining they do not stabilize as good as manual? Is there a trick that I do not know about please help?
2002 Chevy 1500HD
2015 Flagstaff 832IKBS Diamond
beeman is offline   Reply With Quote
Old 10-30-2014, 08:41 AM   #2
TURBS's Avatar
The trick is to add strong arms such as jt's or bal's.
Love my electric jacks.
Turbs
Old 10-30-2014, 08:54 AM   #3
beeman's Avatar
2002 Chevy 1500HD
Old 10-30-2014, 09:31 AM   #4
Brother Les's Avatar
Not hard to install for different applications.
http://www.happijac.com/~happicja/im...stall_2009.pdf
Brother Les
Old 10-30-2014, 10:35 AM   #5
Turbs
Turbs, do you have to manually place those strong arms each time? If so, would using manual scissor jacks with a drill be just as quick (or quicker).
Reason I ask is that the wife does not like the wobble, and I can see the stabilizers moving. Many folks that I've talked to suggest to either dump the electric stabilizers altogether and replace with scissor jacks (bolted in place), or put a scissor jack on each side near the wheels (in addition to the electric).
I have scissor jacks I purchased, and from playing with them I think I could stabilize a trailer (using a cordless drill) as fast or faster than with electric. I'm going to try next weekend to use just those jacks and see how they compare to the electric.
Republic of Texas
2014 Rockwood 8325SS Platinum
Nights Camped: 2014-12 (since Oct), 2015-2
Hilgert is offline   Reply With Quote
Old 10-30-2014, 10:38 AM   #6
TURBS's Avatar
Yes you manually have to loosen and tighten each time.
A set of scissor jacks by the axles are always a good idea to eliminate bounce.
Turbs
Old 10-30-2014, 10:40 AM   #7
Wow...quick reply...thanks.
I'll probably try two near the wheels at first...if that works then I might leave the electrics.
Republic of Texas
Old 10-30-2014, 10:48 AM   #8
TURBS's Avatar
Out of curiosity where are you from?
Turbs
Old 10-30-2014, 10:50 AM   #9
I do have scissor jacks (along with electric stabilizers) and did not like the clearance when the jacks were in the up position. The side skirts hang way down and were in the way of the jacks and the gas line was way close to the I-beam. I installed a 'sav-a-jack' quick release to put them on and off when needed or not.
SaveAJack Quick Release Jack Saver
Brother Les
Old 10-30-2014, 10:57 AM   #10
Turbs
I live in a small town north of the DFW area in the Republic of Texas (as we Texans like to call it). PM me if you want more specifics (like if you need my address so you can deliver my Publisher's Clearing House winnings).
Republic of Texas
electric, jacks
