Old 08-15-2016, 09:09 PM   #1
danielabram71's Avatar
Electric tongue jack
Ok I never thought about this. I thought they was pretty weatherproof. But my jack is not working. It will try the fuse is good. I can use a wrench on it. When I took the plug off top was wet inside. Can it be saved or is it done for and need replaced.
1014 1500 GMC
2015 solaire 267bhsk
danielabram71 is offline   Reply With Quote
Old 08-16-2016, 09:10 AM   #2
ryand's Avatar
Do you know the brand? Lots of failures of the LCI factory supplied jacks documented on this page. Water pretty much can find its way into anything...I keep mine covered with a 5 gallon bucket and attach the chains to the handle so the wind does not take it.
if the fuse is good, check to see if its getting power. The switch could also be bad. If its the motor, you likely will be finding a replacement jack.
2011 Coachmen Catalina 28DDS
2015 Ram Bighorn 2500 6.4L
http://www.ryandethrow.wordpress.com
Nights Camped 2016: 32
ryand is offline   Reply With Quote
Old 08-17-2016, 07:08 PM   #3
WestCoastRV'er's Avatar
Had the same issue. Ended up taking the electric motor apart on a camping trip, removed the rust inside on the rotor and stator. Lucky for me that fixed the issue for now. I now use a cover to keep water out.
Best of luck.
2011 2902ss Rockwood Ultralight
2008 Grand Cherokee 3.0L Diesel (255 hp @ 2900 rpm / 430 lb-ft @ 1,400-2,800 rpm)
3P ProPride Hitch
RV Mods
Wandering RV Life
WestCoastRV'er is offline   Reply With Quote
Old 08-18-2016, 08:44 AM   #4
raspivey's Avatar
I've had to fix / replace two because of this. The first jack seized the motor up and a crank wouldn't even turn it. Had to take the gears out of the top (was half hitched up at the time) to get it off the truck. The replacement jack was a different design, but managed to get water in the switch housing. Corroded the contacts clean off. Replaced the switch on that one. I cover them now but you'd think something designed to be on the outside of a trailer would be more water tight....
2012 Chevy Tahoe LTZ - HD tow package
Old 08-18-2016, 09:08 AM   #5
Just my experience, I had thought the one I used to have went bad as well. I checked the connection to the battery and it was just a tiny bit loose. Tightened it up and it worked fine. Must really need good contact to work.
But with water in yours that points to something else.
Dwayne and Susan
Jiro and Phoebe-4 legged family members
Mike and Dana - Traveling buddies
2016 Ford F350 XLT 6.7 Powerstroke DRW 4X4
2016 Brookstone 395RL
dwayneb236 is offline   Reply With Quote
Old 08-18-2016, 09:29 PM   #6
Yes I think it does too. And the sad part is the plug had never been off of it smh. Live and learn. Bet the new one will stay covered
1014 1500 GMC
Old 08-21-2016, 08:21 PM   #7
Well I have been working on my jack and if I tap it on the sides it will try to run. The two screws on top I can get to. But there are two that you need a 6" + screw driver to get the cap off. So I hope to get in there this week. It may be a lose wire or something but I hope to find out soon
1014 1500 GMC
Old 08-22-2016, 12:30 AM   #8
1014 1500 GMC
It could be the grounding. These jacks are grounded via the mounting bolts. If I remember when I installed one there was a star washer that went under one of the mounting bolts between the base and the trailer tongue to help ensure a ground connection. I would take the bolts loose and use a wire brush to make sure you have a good ground contact.
2016 Siverback 33IK
2015 Ford F-250 Lariat 6.7L V8 Diesel 4WD Super Cab
Old 08-22-2016, 01:33 AM   #9
Croaker's Avatar
Like RYand, I keep a bucket on mine.
I have a Barker brand. This is my second trailer with this brand electric Jack. They are "made in USA" and very good quality.
Croaker is offline   Reply With Quote
Old 08-22-2016, 03:31 AM   #10
Buy a Barker,made in the USA and very good jack,BUT buy and Use the "Barker Cover" they Might "GIVE" you a cover where you purchase! Youroo!!
electric
