Old 03-27-2008, 11:03 PM   #1
wildwood's Avatar
electrical service
I have a LE29bhbs
It has a 30 amp main service, one ac unit. Is this adequate. I 30 amp pretty typicalfor rvs.
also, how does the electrical system work
12 vdc to converter/inverter to load
120 vac to charger/ inverter/converter
i notice inverter/converter is behind ac panel board/circuits
what is inverter and what does it do
what is converter and what does it do
what maintenance required
brief electrical system description please
what adaptor plugs are helpful for the electrical
thanks
wildwood is offline   Reply With Quote
Old 03-28-2008, 08:52 PM   #2
About all I can help you with is that 30 amp is typical for most size travel trailers. As they get larger some manufacturers will put 50 amp service in them. I do have an adapter that I attach to my trailer cord so I can plug it into a standard outlet at home which is 20 amp. I only run lights occasionally and the refrigerator at home (extra cold beer in the summer when at home working outside) so 20 amp is fine for that.
As for the rest, as long as everything works when I plug it in, I'm happy.
Hokiehall is offline   Reply With Quote
Old 03-28-2008, 09:30 PM   #3
welshman599's Avatar
Send a message via MSN to welshman599
Lot of questions there Wild. As my son said when I asked him to name the provinces of Canada, "Do I look like Google?"
Here some links though. Guess I am Google after all.
http://www.newrver.com/electricity.html
http://www.trailerlife.com/abc/abc_index.cfm
http://www.keystonerv.com/media/manu...Electrical.pdf
  • Salem 401-2b; 31" Sony Trinitron and two channels on the antenna.
  • Smokin' hot wife... 2 boys, 25 and 10.
83 sweet sweet days camped in 2008 - not easy in my neck of the woods!
welshman599 is offline   Reply With Quote
Old 04-04-2008, 10:22 PM   #4
wildwood's Avatar
