Old 05-18-2019, 11:24 AM   #1
Ems need water proofing?
Hey guys, just bought a used Progressive Industries EMS. I was just wondering if I need to cover it when it rains? It is a portable unit. Thanks.
shadows4 is offline   Reply With Quote
Old 05-18-2019, 11:39 AM   #2
dbledan's Avatar
If hung vertical you dont have to supposedly as there are drains but being electricity I cover mine. Only takes a spider inside to plug drain holes and zap.
Either a 5gal bucket on the pole or I put it in/under a tote on the ground. Prevents theft a bit too out of site out of mind. Ended up cutting up a toolbox from habor freight to store mine in and keep connections dry.
dbledan is offline   Reply With Quote
Old 05-18-2019, 12:08 PM   #3
jeff64's Avatar
I cover the post and EMS with a 30 gal trash bag and take up the slack with a large binder clip. Outtakes sight and out of the elements.
2016 Flagstaff 27VRL Emerald
14K Equalizer
2014 GMC 2500HD CC 4X4 6.0L
Old 05-18-2019, 12:11 PM   #4
A light rain.... we don't worry about it.
A downpour....we put something over it. Since no two campsites are alike, we usually find something to put over the pole. A bucket or a tote usually works. We don't cover it completely.
Happy Camping!
2015 Dynamax REV 24TB class C
2nd rig 2006 Toyota Tundra &
2010 Cikira 21RB 19' travel trailer
Reverse_snowbird is online now   Reply With Quote
Old 05-19-2019, 02:27 PM   #5
First of all, good on you for buying it! I wouldn't be without mine. Yes, I keep mine covered, but just to be safe.
2018 Rockwood Signature Ultra Lite 8311WS
Chazman is offline   Reply With Quote
Old 05-19-2019, 02:29 PM   #6
BandJCarm's Avatar
Mine laid on the ground under Lake Infield at our first FROG, for about 5 days. It still works. I do know others who have had them go completely out due to water getting inside.
If mine hangs down, like it does at most places, it's fine,
FROG AR-0019-242
BandJCarm is offline   Reply With Quote
Old 05-19-2019, 04:41 PM   #7
Had a problem with my PI EMS the other day, EMS tripping out, I called the factory it seems the light in the pedestal was the problem. I heard you had the same problem.
spock123 is offline   Reply With Quote
Old 05-19-2019, 04:50 PM   #8
BandJCarm's Avatar
Eaton power pedestals have a light that comes on via sensor at dusk. If it's not really grounded well, the EMS (some of them) will register a E6 High Frequency error and shut down for a few seconds.......then cycle on after 2 minutes 41 seconds.
I just taped over the sensor so light was on all the time.
FROG AR-0019-242
Old 05-20-2019, 09:55 AM   #9
GLBCamper's Avatar
This explains so much! I was having the opposite problem. Mine was cycling off early morning (I now realize likely dawn) if I remember right it was even the Low Frequency error.
I was a bit mystified since it was at multiple state parks and I couldnít figure out why so many parks had electrical issues. Oregon State Parks use the ďnon-metallic Midwest ParkMateĒ. But I suspect itís the same issue.
The problem is that my microwave beeped on restart and would wake us up so Iíve taken to unplugging it before bedtime.
2016 EVO (Sonoma) ATS 201rd 24í TT
2016 F150 4x4 Sport
GLBCamper is online now   Reply With Quote
Old 05-22-2019, 03:15 PM   #10
This is what Iím going to do, I plan to hang my EMS in my basement. I plan to cut my 50amp camper cable from where it plugs into the camper. I have a 15ft 50amp cable coming from amazon. I plan to cut the male end off that cable and splice those two cables together. Then I plan to splice the female end of the 15ft cable to my original 30ft cable. Iíll take pictures of everything. That way my portable EMS will be away from the pedestal and away from a high or low frequency. Plus out of the weather. Anyway thatís the plan
roo, roof, water
