Old 09-29-2015, 09:23 PM   #1
Enclosing the underbelly
Bought my 2015 Primetime Avenger 27bbs ATi, it does not have the heated or enclosed underbelly. I noticed that the water lines are exposed along with the all three tanks underneath. Here's my idea:
Gonna use Severe weather rated pressure treated plywood from lowes. Starting front to back I am going to attach the wood to the outer framing with stainless steel self tapping screws so it can be removed if needed. As I hang each piece I am going to place insulation on the top side of the wood to insulate the tanks, etc. I will continue this until I reach the rear ensuring a solid "seal" for the entire under carriage. I understand I will have to notch for drainage and things like that. I figured at about 50lbs per sheet x 7 sheets it will add about 350 lbs total.Does this sound like a decent idea? Any concerns?
rhino_160 is offline   Reply With Quote
Old 09-29-2015, 10:01 PM   #2
Platokidd's Avatar
Why not use corrugated plastic underbelly material?
2014 LaCrosse 323RST-TE-C
2009 Chevy 2500HD Z71
nights of camping
2017-67 / 16-92 / 15-73 / 14-60 / 13-33
Seasonal
Old 09-29-2015, 10:38 PM   #3
Where can I get large enough sheets?
Old 09-29-2015, 10:43 PM   #4
Learning a lot as I go...
I think I would use foil faced foam before plywood. Lighter weight, water proof, and insulates all at the same time.
stevejahr is offline   Reply With Quote
Old 09-29-2015, 10:49 PM   #5
Iwannacamp's Avatar
Plastic cardboard sheets on line at Home Depot. 4 x8 sheets
2017 Puma 297RLSS
2005 Ram 2500 4X4 diesel
Our new 5er 10-26-16
Old 09-30-2015, 07:47 AM   #6
My only concern with plastic sheeting is securement with the amount of wind under there in tow.
Old 09-30-2015, 08:03 AM   #7
Phat Phrog Stunt Crew
elind's Avatar
Look under other RVs. Most of them have a corrugated plastic all one piece under them held in with self tapping screws with washers.
2014 Wildcat 327ck
elind is offline   Reply With Quote
Old 09-30-2015, 08:09 AM   #8
If you wanted to use the corrugated plastic, and since it wont be one piece, my only suggestion would be to go the opposite direction. You said you wanted to start in the front and work back. I would start at the back, and work toward the front. Then you could overlap the sheet about 6-8 inches (or even more, to your comfort level), and it would look similar to roof shingles, then the air (while driving) wouldn't be able to get into the seems.
_________________________
2018 Rockwood Mini Lite 2504S
2018 Ford F150 Lariat Special Edition 3.5 Ecoboost
Semperfi24 is offline   Reply With Quote
Old 09-30-2015, 09:01 AM   #9
Wood would add weight and moisture would eventually get to it. I would do it just like all the others, insulate the tanks with foam and add the corrugated plastic. Wrap the hoses in heat tape/insulate wrap.
2018 XLR Nitro 36T15
2015 GMC 3500 6.6/Allison
Nights Camped (2017- 16) (2016-13) (2015-13)
SuicideSaints is offline   Reply With Quote
underbelly
