Old 01-23-2011, 09:52 PM   #1
Eqaulizer hitch noise... New TT
Left Houston early Saturday morning and drove to Ft Worth to pick up the new TT... Then made a detour on the way home to Sam Rayburn reservoir and spent Saturday night and Sunday there.. found the usual.. minor cabinet work... a water leak... trim piece blowing in the wind on the way home.... nothing that can't be fixed... and I didn't by a Prevost... so be it... BUT.... the equalizer hitch made such a racket every litle twist and turn you made it would wake the dead! Suggestions?
sleblanc63 is offline   Reply With Quote
Old 01-23-2011, 10:01 PM   #2
Lube it!
My guess there is no grease on any of the swivel joints and the noise is actually grinding of metal on metal.
Old 01-23-2011, 10:02 PM   #3
grhodes50's Avatar
It's normal for the Equal-i-zer to make noise, especialy when new. Make sure you lube the tops and bottoms of the sockets located on the hitch where you insert your tension bars. You can also lightly coat the L brackets using a light weight oil. And these Sway Bracket Jackets may help as well;
Sway Bracket Jacket (pair) - RVWholesalers.com RV Parts
Hope this helps.
Gary & Trish
2018 Nights Camped - 5
Old 01-23-2011, 10:23 PM   #4
Infractee
LOL! Ahh yes, the noise that sounds like you are ripping large pieces of metal in half, the sound that thousands of people on the titanic surely heard that fateful night, of metal twisting and stretching and then finally breaking ....oh wait, we are talking about the Equal-I-Zer....
As mentioned above, lube the sockets where they swivel on the head, I use some spray dry lube there and where the spring bars rub on the L brackets, quiets it all down nicely. There is an admonition on the manufacturer web site aboot the bracket jackets and lubing and I quote,
"ATTENTION: Utilizing lubrication on the Equal-i-zer L-Bracket, in the form of the Sway Bracket Jacket or any grease type lubricant, will likely lessen or decrease your sway control by a small degree. Steel on steel is the highest level of friction, steel on lubricated steel second, and steel on plastic third (but also the cleanest). The hitch head can be lubricated, as per the instructions, with no detriment to sway control."
The above info will also be useful for those on the forum that were unsure of how the sway control on the Equal-I-Zer actually worked.
RhoZeta is offline   Reply With Quote
Old 01-24-2011, 06:32 AM   #5
camper_Lucy's Avatar
Yes a "little" lube helps, they also make a plastic insert that rests on the L bracket then the bar sits on top of that. It works very well in keeping the noise down and holds better that lube on that part, I got one a few years ago for the same noise reason.
camper_Lucy is offline   Reply With Quote
Old 01-24-2011, 07:21 AM   #6
Real men read the instructions!
I'm guilty. I "briefly" browsed the equalizer instructions to make sure it looked right when the dealer installed it.... but I did not read them all! And something in my male genes did not refer me back to those instructions this weekend when I was pulling my hat down low and scooting down in the seat as everyone stared at this seemingly new truck and trailer making noises like something out of a scary movie.... wildlife was scattering, kids were running for their mothers... My bad. This forum is great. Thanks for the help.
Old 01-24-2011, 07:54 AM   #7
grhodes50's Avatar
Oh yeah, the looks and stares one gets when pulling into a crowded campground with the Equal-i-zer singing it's song.
I usually just smile and wave!
Gary & Trish
Old 01-24-2011, 08:02 AM   #8
MtnGuy's Avatar
FWIW, I don't think the Reese Dual Cam is any quieter. It sings & pops, but it doesn't sing pop songs.
Old 01-24-2011, 12:10 PM   #9
Retired FF
wrogers's Avatar
Yes, the Equalizer does make a racket, but usually not too terrible. One thing I have found though, is make sure all your torques are where they need to be. The first time I towed with my Equalizer, the side bars had loosened just a little, and by the time I pulled into the campground and was making tighter turns, it was really making an awfull racket that people in the next county were complaining about. When I finally got parked in the site (hard to do when you slump real low in the seat ), I checked and the left side "L" bracket that the tension bar sits on was wobbling all over the place. I re-aligned and tightened everything, and now check pre trip every time. No problems since, just the usual little "melody"
2008 Salem LE 27RB -- 2010 Ram 2500 crew cab 6.7L Hummin Cummins
wrogers is offline   Reply With Quote
Old 01-24-2011, 01:37 PM   #10
frankm's Avatar
If you have the old style L bracket
then according to the manual http://www.equalizerhitch.com/public...ation_faqs.pdf
the set screw should only be tightened until it holds the L-bracket in place so it would (should?) wobble.
frankm is offline   Reply With Quote
