Old 05-17-2016, 03:13 PM   #1
Ever See a Fresh Water Hose Do This?
Camco hose. Notice it is not hooked up and is still pressurized under its skin. Water pressure measured at 48 psi.
Lee and Anne
2016 F250 2WD CC SB XLT 6.2 3.73 3,295 lb payload cap.
2014 Salem Hemisphere 282RK 8k lbs loaded, Equal-i-zer WDH, TST 507 TPMS
2017: 4 nights camped, 12 booked
Teamfour is offline   Reply With Quote
Old 05-17-2016, 03:17 PM   #2
Pickin' & Campin'
Yep, defect.
Return for replacement or throw away and replace.
Days Camped: '15=22 '16=46 '17=30 '18=4
Old 05-17-2016, 03:20 PM   #3
Cyber Phrenologist
Radio's Avatar
That snake ate something.
KU4OJ
Admin at www.openroadsradio.net, part of the Social Knowledge network.
"RVing and Amateur Radio served up on the same plate"
2008 (or is it 2009?) Rockwood 8280SS - 2007 F-150
Radio is offline   Reply With Quote
Old 05-17-2016, 03:31 PM   #4
Dodge Guy's Avatar
That's so you can tell how clean the water is!
02 Ford Excursion V-10 4.30 gears 5 Star Tuner Y-pipe mod Hellwig sway bar Rear Airbags
Prodigy and Dual Cam
07 Cherokee 32B
Better to have a bad day of camping than a good day at work!
Dodge Guy is offline   Reply With Quote
Old 05-17-2016, 08:35 PM   #5
I normally carry two fresh water hoses. 20 and 50 feet hoses. I noticed my 50 ft Camco hose has done the same thing.
2017 Keystone Cougar 28RDB
Buck1032 is offline   Reply With Quote
Old 05-17-2016, 08:40 PM   #6
rockin'ray's Avatar
No an uncommon thing to see. I service commercial laundry equipment and I see this often on older hoses. Most hoses actually should be replaced every 5 years at the most as they can pop like that at any time and cause a big mess.
2013 Wildwood 29BHBS
2009 Toyota Tacoma
The crew;
DG, DH
Tally the Greyhound and Itty the Chihuahua
rockin'ray is offline   Reply With Quote
Old 05-17-2016, 09:00 PM   #7
Yeah, I had another 25' hose as backup. That hose that blew up was a little over one year from purchase and of course out of warranty.
Lee and Anne
Old 05-18-2016, 01:26 PM   #8
NMWildcat's Avatar
We've seen several of the Camco hoses do that. Don't know where you had your pressure reducer but we always put ours on the supply spigot BEFORE the hose to reduce the pressure on the hose also.
Scott and Liz - Southern NM
Old 05-18-2016, 01:34 PM   #9
CDR USN Ret
You get what you pay for. Camco sells lots of crap.
2015 XLR415AMP
2011 3500HD Duramax/Allison/90 Gal Aux
2015 HD Limited Low
DSQR is offline   Reply With Quote
Old 05-18-2016, 04:47 PM   #10
Had the reducer before the hose. Water was still flowing to camper. Just the outer layer filled up.
Lee and Anne
fresh water, water
