Old 09-09-2016, 02:43 PM   #11
Captain America's Avatar
Originally Posted by wmtire View Post
You can buy pre-made extended run kits here:
Generator Brands for Extended Run Generator Fuel Systems | Life Warranty
And there are several videos on youtube showing where people have done the same.
You may can pick up some ideas from both.
Yes, I have contacted them, and they do not offer a duel extended run because champions are gravity fed. According to their website, they have a single extended run, which I guess I can buy two.
Hondas have a fuel pump to draw fuel out of external tank. I have to work with gravity.
I thought about adding a hose barb to the fuel cap, but don't know if cap will seal enough to keep fuel from leaking.
2011 Wildcat 32QBT
2006 GMC 2500, Airsafe 20K hitch, Air Lift Loadlifter 5000 air bags with Air Lift WirelessONE compressor
Jack of all trades, Master on none
Captain America is offline   Reply With Quote
Old 09-09-2016, 02:47 PM   #12
wmtire's Avatar
Have you checked youtube? I thought I recalled seeing one by a guy who made it for a champion where he added his own pump.
Here's one for a Champion inverter type generator, which I am "assuming" you are using.
2011 Flagstaff 831 RLBSS
Wanna know how I plan on cutting carbs next year?
With a pizza slicer.
Old 09-09-2016, 04:03 PM   #13
Follow this link we did all the hard work for you. Simple easy how to. Just read the whole link through took a few people to complete.
Good luck.
Extend gen/inverter run time
AJAbbott is offline   Reply With Quote
Old 09-09-2016, 04:13 PM   #14
I have Hondas and no experience with the Champions but assume they have some similarities. While I dont run mine on an extended tank if I did I would run synthetic oil vs. dino. Check your manual for oil change intervals and from what I have seen it wont take long before it's due. They dont hold a lot of oil anyway so keeping up with your maintenance is something to be mindful of when using extended run tanks. Just my.02
2014 Coachman Clipper 17FQ
2011 Ford Ranger 4X4
Kenrod is offline   Reply With Quote
Old 09-09-2016, 04:15 PM   #15
I did the same thing with a Generac 2000. I went in EBay and found the cap and a boat tank.
NorSnrub is online now   Reply With Quote
Old 09-09-2016, 05:37 PM   #16
Originally Posted by Captain America View Post
I would like to add an external fuel supply to the 2 Champion gens I run in parallel .
How do you phase parallel generators ?
2012 Ecoboost Screw, 3.31 (yes....really) rear end.
2016 Flagstaff 26FKWS, about 7500 loaded
Retired AF Mustang.....Picker always looking to jam.
Major Oz is offline   Reply With Quote
Old 09-09-2016, 06:08 PM   #17
With one of these.
2007 Surveyor SV230
- 200 Watts Solar/MPPT Controller - 230 AH Battery Bank - 600 watt PSW Inverter - (2) 2000 watt Inverter Generators - LED Lighting - Boon Docking 99% of the time.
2009 F150 - 5.4 Litre - 6 speed - Tow Package
boondocking is offline   Reply With Quote
Old 09-09-2016, 08:17 PM   #18
Good luck.
Thanks for the link, but I have the Champion 2000 Watt generators.
2011 Wildcat 32QBT
Old 09-09-2016, 08:41 PM   #19
Usually Confused Member
emm-dee's Avatar
The Honda manual calls for oil change every 100 hours. Sometimes that's not possible but lots of folks regularly exceed that number. I recently ran my two 2000's for 190 hours without shutting down. When I got home and changed the oil it was just as clean coming out as when it went in.
I use the B.E.R.G. tank to feed both units and get 30+ hours between fill ups even running the AC continuously.
At some point during every day you suddenly realize nothing else productive is going to happen the rest of that day. For me, it usually occurs around 9 am.
Vengeance 25V (the Harley needed a home)
Old 09-09-2016, 10:14 PM   #20
parallel 2000's
Hi, I see many of you run the dual gen set-up. Any of you power up a 15,000 btu AC unit? Any advice? I'm looking to purchase a set of Honda's but also like the Generac reviews. - Thanks!
tshelley is offline   Reply With Quote
inverter
