12-06-2014, 11:51 PM
Extreme Weather package
If a unit has the sticker on the side that states "Extreme Weather Package"
Shouldn't it have the below options installed?
Dual Pane Windows
12V Heated Holding Tanks
Radiant Roof/Floor/Slide Out Floor/Front Insulation (R-38 @ 80°F)
2015 Thunderbolt XLR 340X12HP
2019 Ford F350 KR, 6.7, CC, LB with B&W Companion
US Army Retired
12-07-2014, 12:18 AM
Not necessarly. ...the sticker indicates an option..
What does your invoice/options from purchase say? If you paid for the "optional" package then yes...sticker or NO sticker you should have them.
2015 F350 Platinum Fx4 6.7 Diesel Dually. B&W turnover, B&W Companion, air bags and wireless controller.
2015 Heartland Road Warrior 420 Rt
2012 f250 Fx4 6.7 Diesel crew cab tinted n tuned
2012 lacrosse 318bhs touring- sold
12-07-2014, 07:18 AM
The invoice did not have the Extreme Weather option on it.
I assumed (that's where I went wrong) since it had an enclosed underbelly that it had that "option". I couldn't tell if it had insulation installed or dual pane windows.
US Army Retired
12-07-2014, 07:58 AM
Couldn't tell you, but double pain windows are easy to see, they should be about 1/4" space between the glass that is filled with a gas.
Coachmen M/H
Concord
2018 / 300 DSC
12-07-2014, 09:13 AM
Oklahoma Proud
Our dual pane windows have a sticker on them that says "insulated ". You really cant tell visually that they are. But we do have the new "frameless" windows as well.
On our sabre, we had to order the optional radiant barrier, and some of the other more energy efficient options.
Just look at your brochure to see what options are standard or forced.
Good luck!
12-07-2014, 09:21 AM
I agree with MillerTime. What does the brochure say the extreme weather package consists of?
12-07-2014, 02:01 PM
Of all the things I've lost in my life the thing I miss the most is my mind!
12-07-2014, 05:57 PM
This is what the FR brochure states,
Extreme Weather Package:
Dual Pane Windows
Ducted Heat and Radiant Roof/Floor/Slide Out Floor Insulation (R-38 @ 80°F Radiant Technology)
US Army Retired
12-07-2014, 06:36 PM
Dual Pane Windows
I'm wondering how they made radiant floors. That would mean hot water like from a boiler being pumped through plex lines and have to be layed like in concrete. I can't imagine the amount of propane to do that. Maybe they have some new technology that they have developed. I would really like to see how they did that. No doubt they did something and call it Radiant heat. Windows I can understand, pretty common, heated tanks are common. R-38 is great just can't wrap my brain around the radiant heat. I thinking hot water baseboard heating. Even with that it would need a very big hot water heater and plenty of propane with a circulating distribution pump running all the time. I just never heard of it as of yet lets say. The brochert does say that , but also say's op. Did you get that option. It also states options on appliances.
Coachmen M/H
Concord
2018 / 300 DSC
12-07-2014, 06:54 PM
Originally Posted by prairiecamper
Can't agree more! Usually it might be tank heaters, maybe some extra aluminum foil "insulation" somewhere and the all important decal. Ask the dealer or manufacturer if it will be guaranteed against water freeze ups and if it will stay warm in below zero temperatures....Then after the silence, listen for the laughter... Very few if any but the very high end trailers are capable of this type of use...
12-07-2014, 07:06 PM
No boiler needed for electric subfloor heating! STEP RV heating
12-07-2014, 07:10 PM
Oklahoma Proud
The radiant insulation that the op stated is the foil covered bubble wrap on most of that list. And yes i optioned it on my camper, anything to help with keeping heat down (we are lake people, and use our camper the most when its hot out).
Its used in construction as well (foiled, bubble wrap insulation ). Sometimes mini storages will use it. It has hardly any r value but it will help prevent condensation that would occur worse than without any insulation.
...... Whether it helps much in cold, i dont know, but its inbetween my cloroplast and tanks/ & frame. Its all the little stuff that can add up to help alot. I'll order it again if its an option on my next camper too.
12-07-2014, 07:21 PM
Oklahoma Proud
Dual Pane Windows
We have everything on your list also except the 12v tank heaters. Our furnace is ducted to keep it warm in the underbelly.
I ordered everything to help combat heat in the summer- so i guess thats my extreme weather. I also added slide toppers and 2nd ac too.
We have stayed in our camper a few times with the temps in the 30°s and 40°s and lows in the mid 20°s. If you keep the furnace on and all the baggage doors shut it stays comfortable without running to often. It does cool down alot quicker than a house, but it doesnt have the ground contact that a house has.
Best of luck with your quest!!!
12-07-2014, 08:03 PM
That's very interesting concept using electric compared to hot water. but I also read it comes with a 12 gal hot water heater. Also being 24 volt and not the normal 12 volt. Must be comfortable compared to forced air. what gets me to is R-38 insulation also. Nice unit.
Coachmen M/H
Concord
2018 / 300 DSC
12-07-2014, 08:28 PM
Phat Phrog Stunt Crew
When I was at Wildcat this summer Wildcat Chris talked about radiant insulation. He said some companies claim the radiant foil adds a large R value up to R38. The truth is that the foil has only a R1 value and the real value is only in the reflection of heat or cold. So the question is a R24 increases the value to R38 with the "radiant" foil?
2014 Wildcat 327ck
12-07-2014, 08:36 PM
Oklahoma Proud
That wasn't me about radiant heat.
Its radiant INSULATION, not radiant heat that op and i are talking about. On the 5ers I've looked at radiant HEAT, was not an option.
And yes our 12gal water heater is awsome, never have ran out.
And sorry ours has r28 not 38, just looked. Its r14 fiberglass bats and optional r14 radiant insulation (roof and floor) , walls are r9 rated
12-07-2014, 08:46 PM
Oklahoma Proud
To add even more confusion, here is what the download able xlr poster says (in pic) while the brochure says r38. ????who knows? I cant find the brakedown like palomino does for sabre.
12-07-2014, 08:55 PM
From a brochure...
2017 Puma 297RLSS
12-07-2014, 08:56 PM
I dunno about an rv, but the radient tile in my house is the whiz bang snap!!
I know they do it in big motorhomes...guess it could be done in a trailer/5er...?..
one of my neighbors has geothermal floors in his garage/workshop.....keeps it decently warm in sub z with no heaters on......
12-07-2014, 09:40 PM
Oklahoma Proud
I dont know if you could use radiant heat under linoleum or carpet. Seen it for tile and cant remember if ive seen it for wood or not.
Now geo....thats pretty neat, but pretty pricy. My brother was thinking of using it for his new house.
