Old 08-06-2012, 11:07 AM   #1
N3HCP's Avatar
EZ Pass question
Does anyone else use EZ Pass while towing?? We had an interesting problem on a recent trip through New England. We tow with a Ford F-250 with single rear wheels (as far as I know, F-250s don't come with dualies).
Our EZ Pass transponder is from PA and the account has all our vehicles properly registered.
On the way north, on the Mass Pike, we were charged the rate for dual rear wheels, on the way home we were charged for single rear wheels. On the New Hampshire Turnpike the opposite happened. Single rear wheels on the way up, dualies on the way home.
Does anyone know how the EZ Pass toll booths determine the number of rear wheels? My attempts to contact EZ Pass and the turnpikes involved have met with, shall we say, limited success. The amount of the over charges are too little to justify the appeals process but I am trying to find out how this can be avoided in the future.
2013 F-350 Diesel Dually, 6.7L with 3.73 rear with 50 gallon Transfer Flow aux fuel tank, ScanGauge II, Tire Minder on all 10 tires, 2M ham radio, and the ever popular CB.
2014 Surveyor SVF-293RLTS
2014 Clipper 16FB
N3HCP is offline   Reply With Quote
Old 08-06-2012, 11:15 AM   #2
Oakman's Avatar
I've often wondered about EZ pass and now that I've read your post, I'll pass on it.
Bob and Joyce
2013 CC Silverback 29RL
2010 Ford F250 XL Crew Cab 6.4 liter diesel
ATU Local 788
Oakman is offline   Reply With Quote
Old 08-06-2012, 11:20 AM   #3
3 Happy Campers's Avatar
It's actually calculated by axles & class of vehicle not the number of wheels.
I have a Chevy 2500HD which is a class 3 vehicle.
When towing my 5er I'm charged class 3 with 4 axles.
It used to tick me off when we had the class A & towed the car dolly.
Would still be hit with 4 axles.
Dave, Judy & Daisy May
Perkasie, PA
2010 Sierra 356RL
2011 Silverado 2500 4WD, LT, Ext Cab, LB
Duramax 6.6L V8 Turbo Diesel
Allison 1000 6-Speed Automatic Transmission
3 Happy Campers is offline   Reply With Quote
Old 08-06-2012, 11:21 AM   #4
Herk7769's Avatar
This is an interesting issue with as many answers as there are states that accept EZ Pass.
As I understand how it works;
IF the booth is properly configured, the approach to the toll booth counts your axles and weighs them as you pass through. Thus a single transponder works for your regular truck and when you are towing.
It costs a LOT to put in the weight system so some states have "opted out" of that feature (like New York) and some exits on the PA turnpike near Philadelphia there are two that are "NO TRUCKS" due to no scales and no toll takers.
New York REQUIRES a special "trailer" transponder for RVs with toads and trailers (you swap the transponder when you are towing). I tried to get one since we camp in the NE states and drive the NY turnpikes. Can't do it as they are only available to NY residents.
So, how do you tow in NY? Well you can pay cash, OR you can stop at the toll booth and let the operator count your axles and charge your EZ Pass manually.
Sounds like your experience with blind toll takers is right on with mine.
HAM CALLSIGN - KC3FFW
Old 08-06-2012, 11:23 AM   #5
The first metal plate you drive over actually counts the number of axles.
There's no way for it to know how many wheels you have on an axle.
Perkasie, PA
2010 Sierra 356RL
Old 08-06-2012, 11:46 AM   #6
N3HCP's Avatar
That's what I thought. But in New Hampshire I was charged as a class 3 one time and class 7 the other. The difference, according to New Hampshire's web site, is class 3 is single rear wheel, class 7 is dualie. So how did the system decide what class I was??
2014 Clipper 16FB
Old 08-06-2012, 11:57 AM   #7
N3HCP's Avatar
We used EZ Pass on the Newburg Bridge and were charged the correct toll for the number of axles, so at least that bridge is OK with EZ Pass.
2014 Clipper 16FB
Old 08-06-2012, 12:38 PM   #8
IT Guru
Send a message via AIM to jsilvius Send a message via Skype™ to jsilvius
Virginia says that we have to have separate transponders for regular vs towing.
Since I only cross a toll while towing once in a blue moon, I take the risk. They want $35 deposits for each transponder and I just can't justify having two for the truck when I very rarely use it while towing.
https://www.ezpassva.com/StaticPages/FAQ.aspx#43
2006 Flagstaff 831FKSS
2005 Dodge Ram 2500 SLT 5.9L Turbo Diesel Quad Cab
1 - DH (me); 1 - DW (Tee); 1 - DS (Jarod, 12)
Nights Camping: 2010 - 15; 2011 - 7; 2012 - 9
jsilvius is offline   Reply With Quote
Old 08-06-2012, 04:46 PM   #9
My statements were with the assumption that ez pass was standardized. My fault for making an assumption.
I just visited several states toll calculation web sites including NH.
Not only are the states all over the place with how they calculate but in NH if you are not a resident but use ez pass you still pay the cash amount.
A computer is only as smart as the person that programed it.
Perkasie, PA
2010 Sierra 356RL
Old 08-06-2012, 11:41 PM   #10
I have used mine many times, my pass is from NJ (as at the time easiest to get as they sell them at the rest stops) but anyway....NJ says for theirs to utilize the same transponder UNLESS you tow all the time, then they can program it for that specific combo. Since i used to have a third vehicle, i had them reprogram that one for towing and have the other just for the truck....no problems since. Also, they dint care if you are from NJ or not, i live in VA and have an acct with them.....worked all the way up through NH and west through IL.....no problems since the reprogram
2012 Ford F-350 6.7L CC SRW w/FX4
2013 Forest River Sierra 365SAQ
Beausdog is offline   Reply With Quote
