Old 05-08-2016, 08:42 PM   #121
wicked1's Avatar
Originally Posted by 05CrewDually View Post
BELOW IS MY RESPONSE TO WICKED1'S POST #113 FROM ABOVE.
Silly Diesel Question in regards to the Fuel/Water superstar on a 2016 F350 PS 6.7?
Read up in your owner's manual.
How often do you check it?
Drain every time the oil is changed to check for any contamination.
What do you do when you check it?
Drain into a clean pan. Water and fuel oil does not mix so it will show up in the pan.
When there is water in the fuel? How do you get rid of it?
If it's just a little in a pan it's not a big deal. If your light is on and you have a large quantity of water then the tank should be drained to assure all the water is removed.
ONLY USE MOTORCRAFT FILTERS.
2016 F350 SCREW SB 6.7 PS Diesel
2015 FR Rockwood Roo 23IKSS
I did but just wanted to see how everyone else is checking things, some say check every month some say only when you change your oil?
First newer diesel for me so I want to be sure, I have 1600 on it now just went to the dealer so they say bring it in when oil monitor says 25% they will not change it before that, and I bought Blue DEF from Walmart so as time goes on I will get better at maintenance but for now everything covered through Ford except wearable items like pads, belts and filters.
Thanks for all the info
2016 F350 Supercew Short Box 6.7 PowerStroke Diesel
wicked1 is offline   Reply With Quote
Old 07-21-2016, 08:50 PM   #122
Hey ForScan users...check out the DPF Load percentage. It shows 122.9%. How can you have more than 100%? Kinda strange, huh? Do y'all see numbers like this?
2012 CC 36CKTS Touring Edition
[SIZE=2]2015 Ford F-350 CC DRW Lariat
Joe_GA is offline   Reply With Quote
Old 07-21-2016, 08:58 PM   #123
blwnsmoke's Avatar
Yup, nobody knows the exact formula that Ford uses. All 3rd party apps go above 100%. Only true gauge is adding it to your productivity screen which many of us have done now.
2015 F350 6.7 Platinum
2015 Coachmen 360IBL
blwnsmoke is offline   Reply With Quote
Old 07-21-2016, 09:05 PM   #124
Thanks. BTW, today was the longest regen I have experienced to date. It took 24 miles! However, that was all on a mountainous type road with a lot of winding turns, climbing and descending. Accelerating and decelerating the whole time.
Old 07-21-2016, 09:09 PM   #125
BandJCarm's Avatar
Is that a F-150, or an F-15?????
FROG AR-0019-242
BandJCarm is offline   Reply With Quote
Old 07-21-2016, 09:26 PM   #126
Huh? I have an F-350. After posting my response, I understand! LOL! There are so many things you can monitor on a vehicle these days.
Old 07-21-2016, 09:30 PM   #127
BandJCarm's Avatar
LOL
OK, I'll try again..........
Is that an F-350, or one of the new F-35's????????
FROG AR-0019-242
Old 07-21-2016, 09:35 PM   #128
Who Dares, Wins
doc73's Avatar
LOL
Are you goose or maverick?
Sent from my Samsung Galaxy S7
Pat, Jen & Heather... Oh yeah and our trained attack trailer cat, Cinnamon
2015 ChevyHD D-Max
2014 Greywolf 26DBH
doc73 is offline   Reply With Quote
Old 07-21-2016, 09:38 PM   #129
BandJCarm's Avatar
Ha. At this age, closer to Goose.
But that's one fancy display. I have NO clue what it is showing.
FROG AR-0019-242
Old 07-21-2016, 10:35 PM   #130
Too funny, guys! Go to post #33 on page 4. This is a pretty cool and inexpensive tool for monitoring your truck. You can monitor the computers that control the engine, transmission, environmental, etc. I think there are 9 different computers. There are hundreds of points you can monitor and you can read any fault codes. Between the software, the tablet and the OBDII adapter, I only have about $60 invested.
diesel, f350
