Old 07-22-2016, 01:17 PM   #131
blwnsmoke's Avatar
Originally Posted by Joe_GA View Post
Too funny, guys! Go to post #33 on page 4. This is a pretty cool and inexpensive tool for monitoring your truck. You can monitor the computers that control the engine, transmission, environmental, etc. I think there are 9 different computers. There are hundreds of points you can monitor and you can read any fault codes. Between the software, the tablet and the OBDII adapter, I only have about $60 invested.
Beats a $400 edge cts2 any day lol
blwnsmoke is offline   Reply With Quote
Old 07-22-2016, 08:07 PM   #132
B and B's Avatar
My Diesel still the shop. Anyone with. 14, 15, early 16 6.7 l get the regen codes flashed. They were only using the left side for extra fuel during regen. The valve on mine were a little gummed up and one was burnt. They pull the head and installed new exhaust valves.
2017 Heartland Bighorn 3575 Elite with Reese Sidewinder
2016 Ford F 350 SD PS 6.7 SRW Crew Pucks and Reese 18 K Elite
2013 Rockwood 8289WS 2012 Rockwood 2703 SS TT 2007 Golden Falcon 38FLA PM 1983 Corsair 21RB
2015 Ford F250 PS '13 F150 3.5 Eco '09 F150 5.4 l 1987 Merc Grand Marq 1982 Ford E250 CW
Old 07-23-2016, 04:12 PM   #133
wicked1's Avatar
Really, I have an early 16 with 6400 miles so far with no issues. It was just in for the 5000K oil change and they did not see any issues.
2016 F350 Supercew Short Box 6.7 PowerStroke Diesel
2013 Crusader 295RST Touring Edition
wicked1 is offline   Reply With Quote
Old 07-23-2016, 07:50 PM   #134
Hutch333id's Avatar
Did you get any indication of a problem? I only ask because I have a 2016 and the exhaust cleaning flashes up on mine then disappears almost as quickly. It had the 8000Km oil change a couple of days ago but nothing was said about there being a problem.
Richard & Diane
2014 Cedar Creek 38FL
2016 F350 Lariat CC DRW
Retired Metropolitan Police (UK)
Hutch333id is offline   Reply With Quote
Old 07-23-2016, 07:59 PM   #135
B and B's Avatar
Some engines have bee reprogrammed to use both sides. This is a TSB not a recall. If after Regen light comes on the engine sputters and you loose power it needs to be checked. Also they don't have to pull the cab either.
Old 07-23-2016, 11:22 PM   #136
Hutch333id's Avatar
Thanks. No spluttering so I'm banking on it being ok. I will keep an eye out though and at least I have a starting point if things start happening.
Richard & Diane
Old 07-27-2016, 07:08 PM   #137
Tweez's Avatar
I don't have the exhaust brake, but I do let it cool down after towing, it gets cool oil to the turbo saves the bearings
2011 Ford Super Duty
6.7 Diesel, Firestone Ride-Rite Air Bags.
2010 Coachman North Ridge 29 RKD 34FT rear kitchen.
" Excess is an often overlooked accomplishment "
Tweez is offline   Reply With Quote
Old 07-27-2016, 07:21 PM   #138
Tweez's Avatar
Originally Posted by TonyD View Post
Anyone who is telling you not to do a turbo idle cooldown is plain flat WRONG and don't listen to them. The only possible exception is if the vehicle you own has a turbo that is water cooled. Water cooled turbos continue cooling the bearings via convection flow after engine is shut off.
The only way to for sure to know if the drive off the main road to your camping site was good enough to cool the turbo down is with an exhaust gas temperature gauge. If EGTs is below 300 deg F then go ahead and shut her down immediately. If you don't have an EGT than follow the Ford diesel supplement instructions with a 3-5 minute cooldown.
My other diesel's owner manual says almost the same thing that the Ford diesel owner supplement manual says which is:
30 second warm up in warm weather
1 minute warm up in cold weather
30 second to 1 minute turbo idle cooldown in normal driving
1 minute to 3 minute turbo idle cooldown in highspeed highway driving
5 minute cooldown when towing.
Is idling your rig 5 minutes after towing going to kill your pocket book or ruin your day with time wasted? NOPE. Having to replace a turbo prematurely will though!
Just follow the instructions in the DIESEL SUPPLEMENT and you'll be ok.
Amen
Old 08-01-2016, 12:27 PM   #139
Captain America's Avatar
I know this is a Ford topic, but if anyone is driving a year model 2005-2007.5 GM 2500 or 3500 Duramax there is an exhaust brake programmed into the ECM. From factory the GM HD trucks during these years only came with transmission braking while tow/haul mode engaged.
GM used the same ECM in the HD and Topkicks. The Topkicks came from factory with Exhaust brake and transmission brake. All you need to do is add a switch to ground on one ECM plug pin in the HD Trucks to activate exhaust brake AND transmission brake on the HD truck. The HD already has the exhaust brake program, but no switch.
I bought a $3 switch and went to GM dealership for ECM pins, 2 hours later I have an exhaust brake.
2018 Refection 311BHS
2011 Wildcat 32QBT (SOLD)
2006 GMC 2500, Airsafe 20K hitch, Air Lift Loadlifter 5000 air bags with Air Lift WirelessONE compressor, EFI Live
Jack of all trades, Master on none
Captain America is offline   Reply With Quote
Old 08-07-2016, 01:09 PM   #140
B and B's Avatar
Update on my engine work. They replaced the exhaust valves on the left bank. Nothing was wrong with them when removed. The reprogram did atop the knock. Had a drop of oil when at home when parked. It has eve loped to something worse on the road Going to see a Ford dealer here at Goshen.
diesel, f350
