04-24-2016, 12:32 AM
#41
[QUOTE=BandJCarm;1173936]Thanks!
FYI, I have to turn T/H on in order to see Transmission Temp on my driver display panel. Otherwise, that slot shows volts. That is on the steering wheel lever. EB is a toggle below the Info readout, along with other toggles.
Just to be sure- am I reading this right?!? You have to be in tow/haul mode to see what your transmission temp is?
2015 Forest River Rockwood Signature Series Ultra Lite 8289WS w/Diamond pkg.
2014 RAM CTD 6.7 Tradesman 4WD Auto Crew Cab Long Bed
Honda eu2200i generators
04-24-2016, 07:24 AM
#42
Originally Posted by TonyD
If you have monitors of EGT temps and it is below 300 deg F then go ahead and skip the idle cooldown. NOT EVERYONE is monitoring their EGTs temps to include me and so a 3-5 minute cooldown after towing is added safety. Idling a diesel engine for 3-5 minutes won't hurt it one bit even with modern emission systems.
What monitor are you using? I like it and want one. Thanks!
Yeah I like that as well, I was thinking of buying the Banks Monitoring System since it doesn't void the Ford warranty but gives me more stuff to monitor?
2016 F350 SCREW SB 6.7 PS Diesel
2015 FR Rockwood Roo 23IKSS
2016 F350 Supercew Short Box 6.7 PowerStroke Diesel
2013 Crusader 295RST Touring Edition
04-24-2016, 08:20 AM
#43
Originally Posted by blwnsmoke
I'll add my name to the list. What are you using? I want to monitor those points, as well. And, it would be helpful to see when the truck is finished with a regen. Thanks!
2012 Cedar Creek 36CKTS Touring Edition
2015 Ford F-350 CC DRW Lariat
04-24-2016, 09:49 AM
#44
I bought an OBDII wifi adapter (bluetooth is available as well) and using a $5 app called FORSCAN.
You can monitor hundreds of PIDS and access every computer the truck has.
This is a little more then half of the computers you can choose and then within each one you can see anywhere from 12 to 100s of options to look at.
The only down side is you can only monitor 1 computer at a time but just about everything I monitor is in the PCM.
I do check my tire pressure occasionally to make sure everything is ok. It uses the factory sensors that you can't pull up on the dash so it is nice to bring the tablet outside with me while filling up each tire and seeing it immediately increase/decrease.
Also has your CEL codes.. here is one from my wife's Explorer and it goes into great detail.
For under $25 (adapter and app) you can do much more then any monitor on the market.
The other nice thing is you can data log so when you are actually monitoring things, it is recording it and you can save it as a file for those pesky "can't duplicate" dealer visits.
Lastly, I bought a cup holder mount for my tablet. I'd highly recommend a tablet over a cell phone. Having an 8" screen is much easier to see then a 4-5" screen. Plus you can fit a lot more on a tablet (25 PIDS)
2015 F350 6.7 Platinum
2015 Coachmen 360IBL
04-24-2016, 12:56 PM
#45
Holy buckets batman. I've flown aircraft that don't monitor that much.
Who watches the road.
Jay & Maria - Camp Dog Joplin
2018 Cedar Creek Champagne 38EL
Fulltimers since May 2018!
2017 Ford F350 Crewcab Dually Diesel
Officially homeless and loving it.
Ham Callsign K9NDY
04-24-2016, 12:59 PM
#46
[QUOTE=tdst51;1174329]
Originally Posted by BandJCarm
Thanks!
Correct.
FROG AR-0019-242
04-24-2016, 01:53 PM
#47
Thanks blwnsmoke. Are there instructions somewhere for loading PIDs? I bought the FORSCAN APP and a WiFi OBDII adapter, but instructions were pitiful. Also, I would have to sit there for hours with the truck idling. How did you get it all set up?
04-24-2016, 03:10 PM
#48
Where do you buy the OBDII wifi adapter? I have a Ford F-350 and iPad Mini3 Tablet? Or does this only work on Android?
04-24-2016, 04:09 PM
#49
This is the one I got, but until I can figure this thing out, I'll have to reserve judgement. I have had it to connect to the FORSCAN App, so I guess it works. I played with it one day and left it plugged in. The next day, I touched it and it was very warm. So, I guess leaving it in is not a good idea!
http://www.amazon.com/Docooler-Wirel...ilpage_o05_s00
04-24-2016, 04:47 PM
#50
I'd be happy to help one on one with getting you setup but first please read through this thread.
FORScan App - Page 8 - Ford Powerstroke Diesel Forum
Starts at around post 78 and then 82 and on. At post 82, I show step by step screen shots on how to get everything going. Frankly most of the thread is helpful but 78 and on is where I start going step by step with screen shots.
If you can't get it figured out after that, then please let me know.
To the person talking about iOS, the app is available for apple/mac/iphone as well. It is slightly different but for the most part you can follow along my posts using Android to figure it out.
A couple notes.. if you are using your cell phone instead of a tablet and using a wifi adapter, your cell phone will not receive data (emails, picture mail etc) that requires a data connection because that data connection is now on a wifi network.
You can use a bluetooth adapter however I can't help with the initial connection because I've never done it via bluetooth.
If you are going to use a tablet, I'd recommend the wifi adapter. Here is an adapter from Amazon that I use.
amazon
I've left mine plugged in for 7 days without an issue but keep in mind that it will continue to use battery power because it stays live even with the ignition off.
Any other questions, let me know.
04-24-2016, 08:01 PM
#51
Recently new!
Wowwwwie!
Thank you for the info, Mr. Smoke! Awesome. You got me to looking into this. Who knew there was so much accessible data!
1987 Starcraft Nova tent trailer, purch. '87, sold 8.14
2013 Crusader 290RLT bought new, 8.14 lotsa mods!
2001 Ford F-250 7.3
Loving wife, R.I.P., 6/6/19
and Mason the always dirty dog! R.I.P, 2/19
04-25-2016, 06:09 PM
#52
Thanks Smoke! I had chores to do today and couldn't try it, but I will tomorrow.
04-25-2016, 06:56 PM
#53
No problem. I have tomorrow off from work so if you have issues, just post.. I should be quick to reply back.
04-25-2016, 08:19 PM
#54
I don't use the tow/haul on my 3500 when towing my fishing boat, or ATV utility trailer.......well not very often.
I assume I will use it all the time with the 5'er.
On Chevy, the 'jake brake' isn't really an engine brake. It's a transmission shifting device, much like tow haul. Not sure having both on simultaneously would help......will have to experiment. Ford and Ram are different though.
I'm not sure who started the whole "GMs isn't an exhaust brake" theory, but clearly they are wrong
http://gmauthority.com/blog/2015/03/gmc-explains-how-its-diesel-exhaust-brake-technology-works-to-reduce-brake-wear-video/
04-25-2016, 08:39 PM
#55
Originally Posted by polishdon
Maybe my misunderstanding?
___________________________________
A compression release engine brake, frequently called a Jake brake or Jacobs brake, is an engine braking mechanism installed on some diesel engines. When activated, it opens exhaust valves in the cylinders after the compression cycle, releasing the compressed air trapped in the cylinders, and slowing the vehicle.
From your link on GM Exhaust brake:
What the technology does is assist the truck in stopping while descending down hills to reduce the wearing of the truck’s brakes. It utilizes the diesel engine’s turbocharger back-pressure in an efficient matter, because hey, why let all of that energy go to waste?
Not sure those two are the same thing.......but maybe they are.
FROG AR-0019-242
04-25-2016, 09:22 PM
#56
I'm with you on this one
04-25-2016, 09:32 PM
#57
BandJCarm, I was just pointing out that it is more than just a transmission shifting device. someone else in another thread said the same thing.
2019 Silverado 1500
No camper, currently
04-25-2016, 09:56 PM
#58
I probably said it because that's probably what I think/thought.
I really don't know diddley squat about it. A Ram guy told me "That ain't a real jake brake" and I believed him.
FROG AR-0019-242
04-25-2016, 10:08 PM
#59
Oklahoma Proud
X2
Gm uses the turbo vanes to slow the truck in their exhaust braking system.
I think people are misunderstanding the "works in conjunction with transmission and cruise control" with them all doing the same thing.
This is incorrect, it merely means that all the systems work in unison and adjust themselves to accommodate the other options you have selected at that time. ie...tow /haul, cruise, and exhaust brake.
So any layman terms....you just select the driving options you prefer, and everything will work properly and in the way you want them to with out adverse side effects.
04-25-2016, 10:11 PM
#60
Oklahoma Proud
He's right, its not. Jacobs is just a brand of exhaust brake.
None of the big 3 use anything like it from what I've seen.
