04-22-2016, 11:47 AM
F350 Diesel Question
When do you enable Exhaust Braking?
I am towing a Rockwood Roo loaded weight 5500, but not sure if it should be on all the time when to/haul is on or if it is just for heavy loads or steep hills?
Also after towing should the truck run for a few minutes to cool down, last time I drove a Diesel it was the 1990's so just wondering if I can just turn the key and go? And is it ok to just shutdown the truck for small trips?
2016 F350 SCREW SB 6.7 PS Diesel
2015 FR Rockwood Roo 23IKSS
2016 F350 Supercew Short Box 6.7 PowerStroke Diesel
2013 Crusader 295RST Touring Edition
04-22-2016, 11:52 AM
Who Dares, Wins
Curious about the "cool" down myself actually..
I leave my tow haul and EB on all the time when I tow.
Sent from my SAMSUNG-SM-G870A using Tapatalk
2015 Chevy HD D-Max
2022 Impression 315MB
04-22-2016, 12:00 PM
I leave the tow/haul on whenever I have the 5th wheel attached. It makes a great different when stopping or going down hills. Also the tow/haul mode via the computer changes the shift points and such for the vehicle. The mfr instructions say when ever you tow you should have the tow/haul mode on.
I try and let the engine warm up a little bit before taking off in the morning. When we stop for lunch or something on the road I just turn the truck off.
04-22-2016, 12:02 PM
I don't use the tow/haul on my 3500 when towing my fishing boat, or ATV utility trailer.......well not very often.
I assume I will use it all the time with the 5'er.
On Chevy, the 'jake brake' isn't really an engine brake. It's a transmission shifting device, much like tow haul. Not sure having both on simultaneously would help......will have to experiment. Ford and Ram are different though.
FROG AR-0019-242
04-22-2016, 12:21 PM
I use the Tow/Haul and Exhaust Brake all the time when towing.
In the winter on Ice and Snow I have used the Tow/ Haul and exhaust brake to keep the vehicle under control. 4 wheels with dynamic braking works really well.
After a long run I do let the engine idle for 30 seconds after parking just to let fluids circulate and the Turbo if it was used as exhaust brake to cool down.
The Exhaust Brake is really that on a Ford. Uses the Turbo to slow the truck.
The Exhaust Brake is really that on a GM. Uses the Turbo to slow the truck. Works with the transmission to change shift points.
B and B
04-22-2016, 12:25 PM
As soon as you engage the tow/haul on the shifter the diesel brake is activated. You can disengage it with the switch on the dash, but I just let it do its thing. As far as cool down goes I wouldn't worry about it.
Bill & Pam
2014 Trilogy 3650RE
2015 F350 PSD
04-22-2016, 12:30 PM
Exhaust brake can be used ANY TIME. Personally, mine is on 100% of the time. Exhaust brakes on these trucks have numerous advantages, most notably that they will help your engine warm up more quickly due to the backpressure they create at idle. The Ram also has a high-idle feature. On a super cold day, I can get the truck to full operating temp within 5 minutes with exhaust brake and high idle, but if I just start it and let it sit, it could idle for 30 minutes and would never get that high.
As for cooling, do you have an oil temperature gauge? Oil is used to cool the turbo, so that's an indication of whether or not the turbo is ready to be shut down. Last thing you want is a super hot turbo cooking the oil it has sitting in it. In my case, normal operating oil temp is about 200-210 degrees. When towing heavy, I often see the oil temp climb to 230. If I come to a stop, I let the engine idle until I see it drop closer to normal temp, then shut down. It's unlikely you will ever have to worry about turbo temperature when driving unloaded, except maybe on super hot days, and it would be dependent on the weight of your right foot.
TV: 2018 Ford F-350 Powerstroke
Trailer: 2013 Palomino Puma 27SBU
04-22-2016, 01:43 PM
Are you sure about that it activated with the tow haul mode. Mine has light on the dash that shows if the exhaust brake is on or off and if I turn on Tow Haul Mode the light doesn't lite. I have to push the button on the dash for the exhaust brake light to come on.
2017 Fleetwood Discovery LXE 40D Diesel Pusher 41 foot. CC 5740
2017 Solitude 310GK-R Pick Up Oct 24th.
2016 GMC Denali 1 ton Cargo Capacity 3722 lbs
Sold 2016 Keystone Montana 3711FL
Sold - 2015 Crusader 315RST 5th Wheel -
2015 Ford F350 SRW Cargo Capacity 3744
04-22-2016, 01:45 PM
All great Info guys, I always use Tow/Haul when hauling heavy loads or Towing no matter what. I will monitor the oil temp and tranny temp every trip, and I will always warm up the truck for a minute or so to let fluids circulate.
I also have the supplemental heater that works in the cold until the diesel warms up, keeps the cab warm and toasty. I will watch the temps more over long trips and the heat in the summer although the Roo Hybrid hardly works the F350 I plan on taking care of it to get many good and safe years out of it, just bought it so it is a 2016.
Love this forum all great info more so from ppl with actual experience then anywhere else. 😄
04-22-2016, 02:34 PM
I haul my 36 ft Silverback in tow mode 100%. Use Ram exhaust brake about 50/50 when towing. We are in Atlanta and no hills. The 50 percent comes into play in the N Georgia mountains. I can travel down a 6% grade, LOADED TRUCK AND RV, and NEVER touch the brakes.
Same set up, prior 5er, x the USA mountains of Arizona, New Mexico, up to Grand Canyon, back through gates of HELL in spring storms of Texas, NEVER ANY ISSUE. Truck is Ram 2500; 6.7 turbo diesel. 11 mpg; holds speed control everywhere except mountains. Have it regularly serviced and book maintained at Dodge. I would ONLY COOL DOWN if
stopping after aggressive hills. ( engine winding ).
I drive this truck around town on a regular basis as a 2nd vehicle. Vehicles need to be driven. Hoses, seals, etc work like they should when this happens. Oil breakdown over TIME or MILES! Stagnant fuel is not great either.
I DO NOT spend any time warming it up or cooling it down.
Hey, it works for me. At least the first 67,000 miles 👍
04-22-2016, 02:44 PM
Recently new!
sometimes cool
I was taught by several from the proving grounds to worry about cool downs only after long upgrades pulling or unloaded, or hottest days pulling hard. Run it at idle for 30 seconds to a minute and a half so things get a chance to cool off and stabilize. Otherwise, you leave the oil in a superheated turbine to cook and coke the oil. It all adds up over time. Does not take long to let circulation do its thing.
1987 Starcraft Nova tent trailer, purch. '87, sold 8.14
2013 Crusader 290RLT bought new, 8.14 lotsa mods!
2001 Ford F-250 7.3
Loving wife, R.I.P., 6/6/19
and Mason the always dirty dog! R.I.P, 2/19
04-22-2016, 02:45 PM
I click mine on at the start of a trip, but as I understand, it does not work unless my speed less than 20 mph. I cannot tell if it is working or not, but all of my towing so far has been on flat terrain. I am anxious to hear the answer.
2014 Ford F250 Super Duty, 6.7L Diesel, Ultimate Lariet package
2016 Forest River, Heritage Glen 272RL
04-22-2016, 08:43 PM
I've never heard of that before, but I don't own a Ford, so really don't know. On my truck, the exhaust brake doesn't come on when in tow/haul mode unless you manually turn it on. I always have the exhaust brake on and always drive in tow/haul mode.
2015 Forest River Rockwood Signature Series Ultra Lite 8289WS w/Diamond pkg.
2014 RAM CTD 6.7 Tradesman 4WD Auto Crew Cab Long Bed
Honda eu2200i generators
04-22-2016, 08:49 PM
Not with the ECM programming I have . It is off unless I turn the exhaust brake switch on.
B and B
04-22-2016, 08:53 PM
I watched the Youtube...............but...........what would be the benefit in a GMC of BOTH the exhaust brake AND the tow/haul being on? Downshifting isn't going to occur twice........
What am I missing??
FROG AR-0019-242
04-22-2016, 10:05 PM
GLCM Warrior
I almost always set a 4-minute timer on my cell phone when I pull off the road from a long tow. Here's why (per the Ford diesel supplement):
"To prolong engine life (especially after extended high speed, high ambient temperature, or high GVW/GCW operation, such as heavy loads or heavy trailers), it is recommended that a hot engine be idled for 3-5 minutes. This allows the turbocharged engine to cool down."
As for the Integrated Engine Braking (again from the Ford diesel supplement):
"This feature increases engine braking at higher engine speeds to provide better grade descent control with less brake and transmission wear and tear. This feature is integrated with the tow/haul mode feature. When tow/haul mode is switched on, the integrated engine braking feature will also be active."
If my 5th wheel is in tow, I have the tow/haul mode set to on.
Safe Travels!
2014 Wildcat 312QBX
2014 Ford F350 SD 4X4 CC LB 6.7L PSD
Bob & Debbie, USAF Retired
04-22-2016, 10:47 PM
Same here and this what says for 2015 owners manual.
"GENERAL INFORMATION
Diesel Engine Braking
Press the button located on the
switch bank next to the audio
unit to switch the system on or off
A light will illuminate in the instrument
cluster when this feature is switched on.
You can use this feature with tow/haul to
provide further increased engine braking."
My light is in the center panel just below the word "Reset" it does not come on in tow haul mode unless you press the button. You can tell the difference between it being on (light lite) and when off. I have heard they improved the exhaust brake in the 2015 models.
04-22-2016, 10:54 PM
GLCM Warrior
My light is in the center panel just below the word "Reset" it is does not come on in tow haul mode unless you press the button. You can tell the difference between it being on (light lite) and when off. I have heard they improved the exhaust brake in the 2015 models.
I guess that is a new feature/option in the 2015 models. I don't have that switch or light on my 2014 model.
2014 Wildcat 312QBX
04-22-2016, 11:40 PM
1 minute warm up at idle and 1 minute cooldown at idle for normal driving.
5 minute idle cooldown for towing no exceptions especially at highway speeds.
I have 157k miles on a turbo'd diesel vehicle with original turbo and most folks lose their turbo on this vehicle at 80-100k miles. Have 96k miles on my other turbo diesel and it runs like new with no radial or axial play.
Here is a good post on the topic: Turbo Cool Down - Diesel Forum - TheDieselStop.com
04-23-2016, 12:12 AM
I use the exhaust brake even if I am not towing (if I remember to turn it on), and I always use it and tow/haul mode when towing. A few times last summer in the mountains (S Dakota, Wyoming, Idaho, Utah, Colorado, New Mexico) I used the gear lock out feature to prevent it from going into 6th gear.
I haven't seen anyone address our question "Can I just turn on the key and go?" Even though the new Fords sound like a gas engine, they still have glow plugs, and you should always wait to start until the indicator is off.
AL
2016 Coachmen Mirada 35KB
2016 Jeep Cherokee 75th Ann. Ed.
2007 Corvette Convertible
1997 F-350 CC PSD
