Old 09-30-2012, 08:36 PM   #11
BB
Rotorhead102's Avatar
Hopefully someone who currently has the covers will chime in and give us a review on quality.
Rotorhead102 is offline   Reply With Quote
Old 09-30-2012, 08:37 PM   #12
I installed a fantastic vent cover. You remove 4 screws that hold the fan. Then you use the larger screws supplied to install 4 metal brackets. The cover then sits on 4 post attached to the brackets. The cover is held in place with cotter pins thru the posts. The plastic seem to be about the same quality as other covers I have seen. I have only had mine for 6 months so it' s hard to say how it will hold up in the long run.
Ontario
Vibe 6501
1 Prospector Canoe
2 Mtn. Bikes
4 Hiking Boots
Happy Vibe is offline   Reply With Quote
Old 09-30-2012, 08:40 PM   #13
hkreck's Avatar
How tight is the fit with the pins holding it down compared to screws and nuts?
Henry & Tena
2013 Solera 24S
The Great Escape
hkreck is offline   Reply With Quote
Old 09-30-2012, 08:40 PM   #14
BB
Thanks Happy Vibe
Old 09-30-2012, 08:42 PM   #15
The cover holds tight. There are washers that go between the cotter pin and cover so you have to push the cover down to get the cotter pins in.
Ontario
Vibe 6501
1 Prospector Canoe
2 Mtn. Bikes
4 Hiking Boots
Old 09-30-2012, 08:46 PM   #16
hkreck's Avatar
Thank you Happy Vibe, that's what I was wondering. As I said earlier most of the posting I've seen on them were pro but I did see one that made me wonder about them. Thanks again.
Henry & Tena
2013 Solera 24S
The Great Escape
fan
