Old 04-19-2016, 02:33 PM   #11
Witch Doctor's Avatar
Well I don't know what to say at PPL it shows a picture of a WFCO 8955 and it has one fan, never had WFCO with 2 fans....It says direct replacement, same as the 2 I took out....
Coachmen M/H
Concord
2018 / 300 DSC
Old 04-19-2016, 02:50 PM   #12
TURBS's Avatar
Had one in the front and one in the back.
I posted about it years ago when I first got the Sabre.
2008 2500hd Duramax
2015 Columbus 320RS
2016 nights camped "0"
2015 nights camped "34"
Old 04-19-2016, 03:06 PM   #13
2008 2500hd Duramax
2015 Columbus 320RS
That is what I have on the direct replacement with the charge wizard button on the new board, but never on a 8955 WFCO, the trailer came with one fan and others that were replaced by FR came with one fan, the bearing were always bad on the one fan only so it made noise.
Charge Wizard 4-State charging system built-in.
Dramatically increases battery life.
This converter/charger will not boil the battery!
55 Amp (PD4655V), 45 Amp (PD4645V) and 35 Amp (PD4635V) models available.
The intelligent way to charge and maintain your RV battery.
Easy to install.
A metal enclosure is included in every package for replacement Parallax/Magnatek 6300 Series or 7300 Series Converter.
Inteli-Power 55 Amp Converter/Charger
Model #PD4655V replaces these converter sections: Parallax/Magnatek #6355, Parallax #7355, Parallax #7155,
Parallax #8355, WFCO™ #8955
Inteli-Power 45 Amp Converter/Charger
Model #PD4645V replaces these converter sections: Parallax/Magnatek #6345, Parallax #7345, Parallax #8345
WFCO™ #8945
Inteli-Power 35 Amp Converter/Charger
Model #PD4635V replaces these converter sections: Parallax/Magnatek #6336, WFCO™ #8935
Inteli-Power 4600 Series models can recharge the battery to 90% in 3-6 hours
Coachmen M/H
Concord
2018 / 300 DSC
Old 04-19-2016, 03:50 PM   #14
TURBS's Avatar
Fan running below fuse box.
Easy to install.
Parallax #8355, WFCO #8955
WFCO #8945
Model #PD4635V replaces these converter sections: Parallax/Magnatek #6336, WFCO #8935
Glenn, that's because there's one in the main case of the distribution center and one on the main board.
They are not both on the converter chassis.
Old 04-20-2016, 03:39 AM   #15
Okay gotcha, that makes sense......
Coachmen M/H
Concord
2018 / 300 DSC
fan, fuse
