Old 04-18-2016, 05:59 PM   #1
Fan running below fuse box.
Plugged up the travel trailer (2016 Flagstaff Micro Lite) today to recharge the battery. Notice a fan running below the fuse box. I hadn't notice it before. I am not sure what it is for or why it is running. This is the first travel trailer we have owned, so we are a little nervous about things.
tyna10 is offline   Reply With Quote
Old 04-18-2016, 06:10 PM   #2
SeaDog's Avatar
That is the cooling fan for your converter at different charging loads the fan will cycle on and off that is normal
Retired Navy
Jake my sidekick (yellow Lab)
2016 Flagstaff 26 FKWS
SeaDog is online now   Reply With Quote
Old 04-18-2016, 06:12 PM   #3
Thank you so much for the reply. You have set my mind at ease.
Old 04-18-2016, 06:16 PM   #4
TURBS's Avatar
Was your battery dead?
2008 2500hd Duramax
2015 Columbus 320RS
2016 nights camped "0"
2015 nights camped "34"
Old 04-19-2016, 12:34 PM   #5
MartiB's Avatar
I've also recently noticed a sort of hum - maybe a fan noise - when two or more lights are on in my Salem CruiseLite. Once it's back down to one light, the noise goes away. It isn't very loud - just slightly noticeable.
MartiB is offline   Reply With Quote
Old 04-19-2016, 12:44 PM   #6
B47
See Post#2.
Old 04-19-2016, 01:02 PM   #7
Witch Doctor's Avatar
WFCO uses one fan it is variable speed. If you are hearing it, if it gets louder you can replace it with a ball bearing fan. I had 2 go out. Then switched to a progressive direct replacement. It has 2 fans and I never here them come on. The fan as mentioned above dissipates the heat the convertor fins put off. The more power needed the louder the fan from the RPM...
Coachmen M/H
Concord
2018 / 300 DSC
Old 04-19-2016, 01:03 PM   #8
TURBS's Avatar
The 8955 Wfco units now have two fans, my 2005 had two.
I installed a third !
2008 2500hd Duramax
2015 Columbus 320RS
Old 04-19-2016, 02:22 PM   #9
pt1655's Avatar
Hidee ho
Hello, you will also notice the fan on when the heated holding tanks are on (if you have them with a glacial/thermal package) because the heating pads draw so much power.
When I changed our Surveyor over to LED lights, they draw so much less power that I can have ALL the lights on in the trailer and the fan does not come on! (I've tried it).
Happy Camping!
2013 Forest River Surveyor SP220 Sport 25'
2012 Ram 1500 4X4, 5.7L Hemi quad cab
pt1655 is offline   Reply With Quote
Old 04-19-2016, 02:26 PM   #10
2008 2500hd Duramax
2015 Columbus 320RS
Well that is weird, Mine is a 2012 not a 2005 and only had one fan, I added a second fan but the bearings went out and caused the fan to become loud...I'll have to look that up, as far as I know they still have one fan on WFCO converter. will get back to this.
Coachmen M/H
Concord
2018 / 300 DSC
fan, fuse
