Old 07-08-2014, 07:08 PM   #21
Old Fella
Aussiecat's Avatar
I'm with steel framer. We don't drive slower because we want to upset other drivers, it's the safe thing to do.
Aussiecat is offline   Reply With Quote
Old 07-08-2014, 07:21 PM   #22
dcheatwood's Avatar
Bed length is do-able. Pin weight is the problem for us tundra drivers. That's why I went with the 8282ws. It had less pin weight.
2013 Rockwood 8282WS
Reese Revolution Pin, Reese 16K
2008 Tundra Limited Double Cab 5.7L
Air Lift 5000 w/Wireless Air
Old 07-08-2014, 08:49 PM   #23
DaveSchwartz's Avatar
The 8285 the OP was looking at was already the lowest pin weight of the 828* series (except the 8280 which is 100lbs less because it has no third slide or outdoor kitchen). All the rest are 150-250lbs more pin weight. And even though the 8285 has a dry pin weight of 1187, anything you put in the BR storage (closet, under bed, cabinets), trunk or passthrough will add at least 50% of its weight on the pin. Unless the OP was going to tow as the factory made 'er, the miniscule cargo capacity the OP's TV had would disappear immediately.
A real problem with today's pickups is that the 'everything but the kitchen sink' option packages count against the '1/2 ton' that you would only get with a stripper.
Thankfully, the General gave my 2500HD a cargo capacity of 2487 even though it is the Loaded Truck CC D/A model so I've still got a healthy margin left after loading the 8282, the hitch, DW and stuff in the back seat.
That's why everyone here says you need at least a 250/2500 to tow most 5ers.
2015 Rockwood Signature UltraLite 8282WS Platinum, GY Marathon LRD, TST 507RV TPMS
2005 GMC 2500HD CCSB D/A, Curt E16, Prodigy P2, Garmin RV760LMT w/BC-20 b/u cam
Self restraint is for the young. I'm old and want it NOW!
DaveSchwartz is online now   Reply With Quote
Old 07-08-2014, 08:54 PM   #24
dcheatwood's Avatar
I forgot that some pin weights changed with the 2014 model. My 2013 8282 was listed as 11??.
Old 07-08-2014, 09:05 PM   #25
We ended up going with a travel trailer. It's a Rockwood Signature Ultra Lite. The 8319ss and it has a hitch weight of 639 pounds, which we are much more comfortable with. It doesn't have the island in the kitchen but does have barstools and it still has the recliners which we love. Thank you all for the help!
Grey9712 is offline   Reply With Quote
Old 07-08-2014, 10:01 PM   #26
dcheatwood's Avatar
Good choice. Enjoy
fifth wheel, tow vehicle, wheel
