Old 08-15-2015, 07:46 PM   #1
Filling fresh water tank
Any tips on burping the fresh water tank so it fills?
Afawley is offline   Reply With Quote
Old 08-15-2015, 07:48 PM   #2
Ford Idaho's Avatar
The FW tank has a vent/over flow tube, if it is working correctly "burping" the tank is unnecessary.
Old 08-15-2015, 07:59 PM   #3
Brother Les's Avatar
x2....
Vent tub most likely plugged up.
Brother Les
Old 08-15-2015, 08:16 PM   #4
Blackhat6mike's Avatar
If the vent tube has a "dip" in it between the tank and the fill spout, it will develop an "air-lock" like a trap in a drain and it will not allow the venting of the tank. You may want to try to blow through the vent to see if water is sitting in it.
Mud dobbers will build nest in the vent tube IF there is no screen over the entrance. You can wad up a piece of plastic screen wire and insert it into the vent tube if you don't already have a screen. As long as air can get by, you are good to go.
Aviator Wright Flyer #1919
Army Pathfinder Vietnam, 3 tours
DAV, MOPH, VFW, NRA, 1stCav. ABN
Blackhat6mike is offline   Reply With Quote
fresh water, tank, water, water tank
