Old 10-16-2014, 09:45 PM   #1
RossandDonna's Avatar
Filthy campground behavior
We were watching two families packing up to leave. Much to our surprise we saw both of them put their sewer hose right onto the fresh water tap and rinse out their sewer hoses! If you don't already, please make sure that you use some disinfectant on the whole fresh water tap prior to hooking up your fresh water hose because you never know what the people before you did.
2012 Crusader 290RLT
2013 F350 Lariat Crew Cab DRW 6.7L Diesel
RossandDonna is offline   Reply With Quote
Old 10-16-2014, 10:27 PM   #2
I carry a spray bottle with a diluted mix of bleach and water. A strong mix. I always spray before and after we hook and unhook.
DaveandSue is offline   Reply With Quote
Old 10-16-2014, 11:13 PM   #3
asquared's Avatar
<a href=http://i62.tinypic.com/28rp645.jpg target=_blank>http://i62.tinypic.com/28rp645.jpg</a>
2014 Sabre 34REQS-6
asquared is offline   Reply With Quote
Old 10-17-2014, 04:34 AM   #4
crunchman12001's Avatar
X2--- I let it sit on the tap for a few minutes before connecting hose.
2015 F-250 FX4
crunchman12001 is online now   Reply With Quote
Old 10-17-2014, 04:42 AM   #5
mud yapster's Avatar
You just never know. Gross!!!! Thanks for the heads up I will disinfect from now on.
2014 Palomino Columbus 3650TH
435AH 12V VMax Charge Tanks, 520 watt Monocrystilline Solar Array, Morningstar MPPT TS-60 CC,Morningstar Remote,Cotek True Sine Wave Inverter,Cotek Remote Controller,50amp Progressive Hardwire Surge Protector
2015 Dodge 3500 6.7L 4X4
2011 CanAm Commander XT 1000
mud yapster is offline   Reply With Quote
Old 10-17-2014, 05:22 AM   #6
Park in site, 1st spray water hook up with a diluted bleach mix, check electric then all ok set up camper with water and sewer being the last 2 things on the list.
dblr is online now   Reply With Quote
Old 10-17-2014, 06:45 AM   #7
vinmaker's Avatar
Wow. Thanks for the heads up. I never thought about it but your right. You just never know.
2015 HW296
2006 HW256 (previous pup)
2013 Chevy Tahoe
Equalizer WDH 1000#
Old 10-17-2014, 06:50 AM   #8
Scootdawg's Avatar
WOW that is gross, thanks for all the advise, I will now disinfect also.
Scootdawg is offline   Reply With Quote
Old 10-17-2014, 07:01 AM   #9
mcnabbwr's Avatar
First thing I do is spray with bleach solution then flush the tap.. I let it sit for a couple minutes while setting up and spray again. You can never trust that the tap is clean, it is exposed to the elements when not hooked up.
Bill & Pam
2014 Trilogy 3650RE
2015 F350 PSD
mcnabbwr is offline   Reply With Quote
Old 10-17-2014, 07:47 AM   #10
TURBS's Avatar
Sorry I have to laugh......
You've ate at a restaurant right?
You've all watched 20/20 right?
Better yet...... ever watched bar rescue?
just saying lol
Turbs
mpg
