Old 10-06-2016, 01:51 PM   #1
Shawn.O's Avatar
final trip of the season
Sadly we are taking our final trip of the year this weekend, starting to get pretty cold up here in New England. We'll have full hookups at our campsite and I know you're not really supposed to leave the tanks dry but I'm assuming you don't want to leave any water in there to freeze over the winter and since this will be my last opportunity to take advantage of a dump station I was planning on getting the tank as clean and empty as possible... anyone have any thoughts or advice...??
thanks,
Shawn
Chief, U.S. Coast Guard Reserve
2016 Grey Wolf 23DBH
2007 F-150 5.4 Triton V8
Shawn.O is offline   Reply With Quote
Old 10-06-2016, 01:57 PM   #2
Location: Minnesota ( wishing we were boondocking in the New York Catskills )
After you dump your tanks and roll home, you will put a little water in flushing/blowing out water with antifreeze and/or air ... then you will likely put antifreeze in your sink traps, bathroom trap, maybe a little in the toilet ... so that will put a little liquid in your tanks to protect the seals.
Jeff and Abby
Fur Babies - Xandra Sophia (GSD) and Neo (Min-Pin Mutt who thinks he is a cat)
2015 Tracer Air 235 (previous 1994 Veri-Lite 1130 TC)
1998 Dodge Ram 2500 Quad Cab - 360 - 46RE (Built)
Jeff_and_Abby is offline   Reply With Quote
Old 10-06-2016, 01:58 PM   #3
Prime Member
Fill your water lines with RV antifreeze. Be sure to poor 1/2 gallon into each tank plus some down your sinks for the traps. Leave a couple inches of antifreeze in your toilet bowl.
2016 Coachmen Freedom Express Liberty Edition 310BHDS
2013 Chevy Silverado 2500HD LTZ 6.6L V8 Duramax
Husky weight distribution hitch with sway control
timfromma is offline   Reply With Quote
Old 10-06-2016, 02:00 PM   #4
Prime Member
Do not forget to bypass and empty your water heater before pumping in antifreeze.
Old 10-06-2016, 03:32 PM   #5
Don't forget winterize the outside shower too.
Wiscampsin is online now   Reply With Quote
Old 10-06-2016, 03:47 PM   #6
heavynlori's Avatar
And your washer hookup if you have one
Black tank flush
Sprayer on kitchen sink
Shower head - we remove head and let it run until the koolaid shows up
Flush toilet to get koolaid into the system too
Sent from my iPhone using Forest River Forums 🇺🇸
heavynlori is online now   Reply With Quote
