Old 11-08-2010, 05:57 PM   #1
fireplace doesn't work
I just purchased a 2005 forest river salemn (SMT381FLFB). I can't get the fireplace to work. I checked the outlet and get no voltage. I then plugged the fireplace into a different outlet and it worked. All other outlets in the trailer work. Is this outlet connected to a switch somewhere?
denboot is offline   Reply With Quote
Old 11-08-2010, 06:37 PM   #2
CLASS "A" Senior Member
cfsoistman's Avatar
Have you checked you breakers in the electrical panel? It may be tripped and just needs to be reset.
2007 Georgetown 370TS
aka - RAYNMKR
Driver: Charlie
Navigator: Sheri
cfsoistman is online now   Reply With Quote
Old 11-08-2010, 06:40 PM   #3
Villa Estate 392FLFB
The_Stuff's Avatar
that or the cheap 'push the wire into the plug' plugin is no good. my entertainment plug is like that. need to replace it..
One state/province at a time!
The_Stuff is offline   Reply With Quote
Old 11-08-2010, 07:41 PM   #4
Herk7769's Avatar
My camper (Flagstaff 8526) has a switch next to the floor by the door that switches from (Fireplace - OFF - Microwave) so that I can't exceed 30 amps.
HAM CALLSIGN - KC3FFW
Old 11-08-2010, 08:33 PM   #5
My Wildcat Has the same (fireplace - off - water heater ) .
2010 wildcat 31ts
05 Ford F350 SD PS
camprat is offline   Reply With Quote
