Old 10-26-2014, 03:04 PM   #41
Sharon455's Avatar
We use a little black "stove" heater in our bedroom at home. During winter trips, we load it into the MH and use it for a little while mornings and evenings. Heated blanket in bedroom, so no need to run unattended overnight.
Happiness is just a ride away!
Sharon455 is offline   Reply With Quote
Old 10-26-2014, 03:29 PM   #42
Fireplaces
I have had the electric fireplace...and on real cold nights (below 0*)it really didn't help much.. Had two oil filled heaters.. Ran them 24/7 safe, quiet and toasty...(only fired up the furnace for a few hrs when I first arrived to melt he ice)
Did I mention..2 - 150lbs Rotties help with heating the place up too...
2010 Georgetown 300FWSSouth Florida
speedjester is offline   Reply With Quote
Old 11-17-2014, 05:41 PM   #43
arpipeliner's Avatar
Just installed mine. It's heating better and more than other heater I had.
Name:	ImageUploadedByForest River Forums1416264059.955656.jpg
arpipeliner is offline   Reply With Quote
Old 11-17-2014, 06:02 PM   #44
Attachment 66541
Which one is that?
proggod is offline   Reply With Quote
Old 11-17-2014, 07:02 PM   #45
Name:	ImageUploadedByForest River Forums1416268929.754678.jpg
Old 11-17-2014, 07:07 PM   #46
Originally Posted by dcheatwood View Post
Oh yeah. Worth mentioning here that some campground/RV parks are catching on and posting signs in their offices stating "no electric heater's." Or extra charge for elected heaters. Seems a little off since a/c compressors aren't used in cold weather.
Heaven help us if they ever catch on to how much electricity we're using in the summer to run our air conditioners. Rates will double!
Ham_Bone is offline   Reply With Quote
Old 11-17-2014, 07:21 PM   #47
The CG is $100 more for winter. Pretty common for us if we can find any open with full hook ups. We heat tape and insulate water hook ups. Sometimes leave the hard pipe behind for the long drains. This one is three ft behind camper.
Thinking about a way to store under the camper.
Old 11-18-2014, 07:31 AM   #48
cpaulsen's Avatar
How much trouble is it to add in the unit your self? Wanted one but it didn't have it. After this thread makes me want one more.
It would go under the tv in the 29 RE. Would rather have the permanent install unless better reason. All that is stored in vaccum stuff.
I installed mine under the tv in my 29rlbs. It was just a wood panel there with nothing behind it. Measure the size I needed and shopped HD online. Found the one I wanted and a few days later it showed up. Took me about 3 hours to install and have used it a lot since. Running right now at 32 degrees outside without the furnace on.
cpaulsen is offline   Reply With Quote
Old 11-18-2014, 07:42 AM   #49
Sounds like what I did. Took the shelf out and put it above and ran for a day to make sure about any overheating issues. Then installed the shelf with plenty of room for vaccum stuff. It was around 14 with heavy wind on camper. The furnace kicked on a couple of times last time.
Really liking it so far.
Old 11-18-2014, 07:56 AM   #50
TURBS's Avatar
And this is bs in my opinion!
you pay for 30 amp and 50 amp service so you should not pay more even if your within your service!
Your rate should be the same regardless if your using 12 amps or 29 amps.
I was told a few years ago "Wisconsin dells" I could not use my electric wh, I simply stated I pay for 30 amp service I'm going to use it !
They were not happy so I asked for a discount since I was only allowed about 20 amps of service.
They said then plug into the 20 amp service plug and then discounted my daily rate.
TURBS.
