01-25-2019, 03:48 PM
first time at Full Hookup site - advice?
So far we have stayed at State Parks in GA/SC that only have power/water hookups and a dump station, but next month we are going to AL and staying at a full hookup site.
So what do I need to do this? The same hose I use at a dump station? I'm guessing I don't want to leave the dump valves open, right? Just use it like a dump station I don't have to drive to?
Sam
01-25-2019, 03:51 PM
Correct... just like having a dump station at your site. Same hose (as long as it reaches) and you'll need the elbow that goes into the ground sewer opening. (required by law at many locations)
DO NOT leave the black tank valve open.
There are two different camps on the grey tank(s) but I leave ALL my valves closed and only dump when a tank gets full.
01-25-2019, 03:54 PM
Always Learning
Same hose should work, but it might be short. It's not unusual for me to need 20' or more of sewer hose.
Here's an article that may help:
How to Dump RV Tanks (it’s not so icky!) | Learn To RV
And yes, valves closed until you need to dump. Leaving the gray open or not is a bit of controversy - some do, some don't. Both sides are strangely passionate about it.
01-25-2019, 03:59 PM
Kanadian Kamper
The only plus for leaving the waste gate(s) open.....is to save all of maybe 5 minutes out of your busy day when it’s time to empty.
Volume SWOOSH is how to empty tanks best.
Ken and Terry
01-26-2019, 12:52 PM
If a kid runs or rides his bike through your campsite (poor form!), he'll go right over your water hose or power cable. Maybe trip, too bad, so sad. BUT... kicking over an uncleared sewer hose, the crap will fly! Even cleaned it will likely get damaged.
Best to operate like having your own close by dump station when on a full hookup site, IMO.
2019 Cherokee Wolf Pup 16BHS flipped axle, 5K springs, 400AH LiFePO4, 3K inverter, 400 watts CIGS solar
2019 Ford F-150 S-Crew 5.5 bed V8 w/tow package, ITBC, Tow Mirrors, 3.55, SumoSprings, 7000# GVWR, 1990#CC
Husky Centerline TS WDH 400-600# spring bars
01-26-2019, 01:43 PM
Dahagen
When I am at a full hook-up site, I fill up the grey water tank fast with showers and dishes. I hate it when I am taking a shower and the pan starts to fill up. So I leave the grey tank open until the day before I dump the black. Then when I dump the black, the grey flushes the hose. If I left the grey closed I would have to dump every three days. The black tank will go at least a week.
01-26-2019, 01:44 PM
Leaving the black tank open invites poop mountains. Always good to get 2/3 or more full in black before a dump. Most people like a generous amount of soapy liquid in the gray tank to clean the hose after dumping the black. Otherwise it can be open to allow as much shower time as people like. Learn the schedule that works for you.
"Lurch" = Georgetown 2011 330TS
Toad = Jeep 2016 Cherokee
Pilot = Bob
First Mate = Xiangbing
Crew = Radar, NiuNiu & NaNa
01-26-2019, 01:54 PM
If I’m at a full hookup site I don’t even bring out the sewer hose until it’s time to leave. Only had to hook up early for gray dump once during a nine night stay.
BIRDS AREN’T REAL
01-26-2019, 02:04 PM
X2
01-26-2019, 03:23 PM
I'll leave both closed. The gray fills faster, so sometimes I'll dump 1/2 the gray if needed and leaving the next day. Nice for flushing out the hose after black dump.
01-26-2019, 04:13 PM
agreed, unless you're going to be there for long enough to completely fill your tanks, over several days or a week, then taking out the hose and hooking it up when you first 'arrive' is premature... I find that waiting and doing it when I actually am ready to dump is easier. No hose to trip over. No hose for vermin to climb, etc.
it's your own private dump station, use it as needed.
The Turners...
01-26-2019, 05:56 PM
If you don't have one you will want to get a RV Sewer Hose Support system. Many RV parks require them and some parks are inspected by local authorities to make sure the RV's are using them. I also like the clear connections at one end or the other of the hose to occasionally monitor the discharge. I spend a lot of time in my RV and I like to flush the black tank once a week or so. I use a separate hose for that job.
Hi Rider
Jack and his dog, Amber
2016 Forester 2401W MBS pulling 2006 Jeep Wrangler
2020 - 162 Days and 5,359 Miles
2021 - 113 Days and 3,835 Miles
2022 - 35 Days and counting, and 3,372 Miles and counting
01-26-2019, 06:38 PM
Just a thought, I dont think anyone mentioned yet. You should include a rubber doughnut to your list to have as some sites dont have a threaded drain pipe. You put the donut ring into the pipe and the hose itself or if your setup has a coupler you wud put the hose with coupler into the ring. If you have a multi threaded elbow and it screws into the pipe you have it made. X2 on having a hose rack, a slinky or even a piece of gutter that you prop up, some campgrounds require it be off the ground.
Happy camping.
01-26-2019, 07:03 PM
Yes x3 - my Valves are under my slide so I hook up all my hoses before extending my slide.
XLR Thunderbolt 300X12HP
2014 Ram 3500 DRW
01-26-2019, 09:11 PM
At a full hookup site do not leave any of your waste tank dump valves open, black or grey, once you have connected your sewer dump hose to the sewer receptacle at the site. The sewer hose will connect you directly to the RV site's sewer system, just as if you were connecting your home toilet to,the city sewer system. All of the nasty things that flow into the sewer system at home will be present in the sewer system at your RV park. All of the nasty smells from that sewer system will percolate into your RV if you allow those dump valves to remain open. TRUST ME ON THIS!!
Only open your grey and black water dump valves when needed, or when you are ready to depart the site. Then make sure you flush and close all dump valve piping before you close them all.
Those who say it is Ok to open grey water dump valves with full hookups are wrong. All the grey and black water flows to the same sewer hookup and also allows the fumes and nasty gases from the RV sewer system to enter your RV.
01-26-2019, 09:13 PM
I like to wait until I close the slide just before departure, then pull out the hose and dump.
BIRDS AREN’T REAL
01-26-2019, 09:20 PM
X2
John & Susan, Olivia the dachshund
2011 Georgetown 337DS
2003 Dodge Dakota
Hampton Roads VA
2016 174 Days camping, 2017 66 days 2018 24 days 2019 48 days 2020 25 days 2021 6
01-26-2019, 09:23 PM
Georgia Rally Coordinator
x 3 Later RJD
Traded 2015 30WRLIKS V-Lite
Days camped 2019 62
01-27-2019, 10:28 AM
with our Tankless WH we can take long leisurely showers. 3 of them and the tank is full. We can go nearly a week before the black tank fills up. But I insure there is plenty in the grey tank to flush the hose after dumping the black tank first
2009 Chevy Silverado 2500HD CCSB LTZ Diesel, Fumoto Oil Drain Valve, Turbo Brake activated, 39 gal Aux Tank W/ Fuel Pump transfer, Air Lift Loadlifter 5000 air bags.
01-27-2019, 11:00 AM
Thanks for all the good advice! We will only be there 4 days, so I think I will keep the sewer hose stowed until we are ready to go home. Unless the wife wants one of her long showers...
Sam
