Old 02-07-2015, 11:28 AM   #1
Steeljag's Avatar
First time water pump
We have never dry camped or used water without hookups. The weather here has been great (central Fl) and I've been out cleaning the pool deck and other yard stuff. My TT is sitting over there in its garage and I'm going to pull it out tomorrow.
Having never used the water pump, is it as easy as putting water in the fresh water tank (do I need to fill it) or just five gallons or so? Turn on the rocker switch for the pump, and open the valve(s) ? Will I hear the pump run when I turn it on ?
Anyway, back outside I go! Any info would be great.
Thank you, enjoy your day!
1930 lbs CCC
2014 Jeep Rubicon JK
Steeljag is online now   Reply With Quote
Old 02-07-2015, 11:32 AM   #2
Done with this
You need to sanitize the tank.
I'm a little too truthful, I guess.
Y'all have fun in "Fantasy Land".
4mula1fan is offline   Reply With Quote
Old 02-07-2015, 11:53 AM   #3
Steeljag's Avatar
I will do so! Charged battery, five gallons of water, pump switch on, good to go ? Will I, should I hear the water pump run when switch is turned on ??
1930 lbs CCC
Old 02-07-2015, 12:15 PM   #4
Pixelbum1's Avatar
Let me help! Yes! You "should" hear the pump running unless they REALLY have it insulated, which I doubt! In my previous TT (now have a motorhome) which was an Airstream I could always hear it as now with the MH. So, not to worry. Sounds like you have the sequence correct. I did see the suggestion for sanitizing the water tank which always is a good idea. Call your local dealer, or Google it, for the correct bleach to water ratio. I think all you need is around a 1\20 amount bleach to the holding cap. in gallons of your tank. After a few hrs, then drain that and perhaps put about a gallon of white vinegar into the tank and fill all the way again with water. Let sit for an hour or two and pump it out. If you can drag the trailer around a bit to let both solutions slosh that probably would be more thorough. Always dilute the bleach , or vinegar, INTO a water-filled tank as you don't want to screw the pump up with straight chemical by chance,,,savvy? Good luck and have fun. Enjoy that weather down there...only about one more healthy month before I can "de-winterize" my Solera and get out! :[
Pixelbum1 is offline   Reply With Quote
Old 02-07-2015, 12:28 PM   #5
Yes, you should hear the pump when you flip on the rocker switch.
This is the way I sanitize my system.
Use 1/4 cup of unscented household bleach for every 15 gals of water. Fill fresh water tank full with the bleach/water solution and then turn on each faucett individually until you get a stream of water. Leave solution sit for at least 3-4 hours then drain the fresh water tank and hot water tank. Refill fresh water tank with straight water and open each faucett again to get rid of bleach solution. Drain tank and water heater once more.
Then refill fresh tank and you are good to go.
2007 Surveyor SV230
- 200 Watts Solar/MPPT Controller - 230 AH Battery Bank - 600 watt PSW Inverter - (2) 2000 watt Inverter Generators - LED Lighting
Boon Docking 99% of the time.
2009 F150 - 5.4 Litre - Tow Package
boondocking is offline   Reply With Quote
Old 02-07-2015, 10:22 PM   #6
WFD
Does anyone ever do this procedure and bypass the hot water tank. My thought is that since the hot water tank only holds 6 gal of fresh water, will it be difficult to flush it enough to get rid of any residual bleach solution, and given the temperature that water reaches when heated, is it really necessary to sanitize the hot water tank. Seems like the same idea as avoiding putting RV antifreeze in the hot water tank?
2016 Chevy Silverado 2500 Duramax
2016 Rockwood 8289WS, Diamond Pkg.
WFD is offline   Reply With Quote
Old 02-08-2015, 12:53 AM   #7
Once the HWT is drained and refilled with fresh water there is no residual bleach smell. It may not be necessary to sanitize the HWT seeing as a person does not drink the water from it, but some people have experienced smelly hot water from bacteria growth. I sanitize mine just so I never have to experience that issue.
2007 Surveyor SV230
Old 02-08-2015, 01:48 AM   #8
Unless your are keeping your WH in "bypass" and don't plan on using it, you should sanitize it. You may not drink from it, but potentially harmful contaminates still pass through the same water fixtures as your cold. You risk cross contamination.
rana is offline   Reply With Quote
Old 02-08-2015, 07:56 AM   #9
mjones12's Avatar
I really do not think you will hear the water pump when you switch it on. In every unit I've had, the pump operates "on demand." It will come on when you turn on a tap or flush the toilet. Maybe others are different, but that has been my experience.
2018 Coachmen Apex 249 RBS
2010 Silverado LT 5.3 V8
The world is a great book, of which those who never stir from home
read only a page. - St. Augustine
mjones12 is offline   Reply With Quote
Old 02-08-2015, 08:48 AM   #10
X2.
biznsa is offline   Reply With Quote
first time, pump, water, water pump
