Old 03-02-2014, 02:03 PM   #21
Ford Idaho's Avatar
Originally Posted by SKnight View Post
Well something's holding it up and I haven't seen too many with .
And a jack under the axle will still lift the tire off the ground even if his unit has torsion suspension.
It is all about knowing what you have and what you may need to deal with stuff.
Old 03-02-2014, 02:06 PM   #22
Platokidd's Avatar
Originally Posted by Ford Idaho View Post
And a jack under the axle will still lift the tire off the ground even id his unit has torsion suspension.
Dual leaf spring dexter axle below the leafs no torsion axle.
2014 LaCrosse 323RST-TE-C
2009 Chevy 2500HD Z71
Seasonal
Zelda the campin dog
Old 03-02-2014, 02:10 PM   #23
Ford Idaho's Avatar
Yes I saw that....
Old 03-02-2014, 02:14 PM   #24
Well something's holding it up and I haven't seen too many with torsion suspension.
Really,I am glad that you know what type of unit (EddyG) has! I am glad that it wasn't a (Rockwood or Flagstaff) since they have (Torsion). Youroo!!
Old 03-02-2014, 02:23 PM   #25
Platokidd's Avatar
My bad I didnt mean to highjack or step in many pardons to the Op but I do have the same issue.
Seasonal
Old 03-02-2014, 08:42 PM   #26
SKnight's Avatar
And if he did I'd have admitted being wrong.
Old 03-02-2014, 08:56 PM   #27
davel1971's Avatar
a 20 ton bottle jack is overkill. That's a lot of weight to carry. We jack up 45,000 lb tractors and combines with that size. Not necessary for a 8-12000lb trailer. 10 or 12 ton will be plenty and much lighter to tote around.
David & Lynn
Old 03-03-2014, 11:13 AM   #28
Wow, thanks for all the great imformation, this is a great site, much more than I expected, now I see that I assumed that there would be a one all jack for my camper, now I know I need to check it out for the best jack to put under it and be perparred to know how to use it. I will use the great imformation I was given and hope someday I can return the favor to some one else in need.
Eddy G is offline   Reply With Quote
Old 03-03-2014, 11:14 AM   #29
What are some suggestions for road help besides AAA, to give me some choices to compare if there are any others you all would recomend please.
Old 03-03-2014, 11:31 AM   #30
SKnight's Avatar
My dealer talked up Coach Net big time. Made it seem almost too good to be true actually.
Home Page - Coach-Net.com
Old 03-03-2014, 11:56 AM   #31
Woo hold up EddyG,before you ask more PLEASE post in your Info what kind of unit you have,year,ect. This will help ALL of the Members Help YOU when they know what we are talking about! Also please start a NEW post,adding on to this post gets VERY confusing!! Youroo!!
Old 03-03-2014, 11:58 AM   #32
Trailer aid plus and 22" breaker bar with proper size socket. Use torque wrench to tighten down.
2012 F350 Lariat CC SRW 6.7L Powerstroke
pwrstroke2012 is offline   Reply With Quote
Old 03-03-2014, 12:33 PM   #33
Arefbee's Avatar
Trailer Aid with a board to lift it a little more, torque wrench, (I set the lug torques to the correct level before camping the first time each season: I needed my impact wrench to get them free since they were all beyond the specified values the first time), a lug wrench to fit the lugs and a 2 foot pipe to extend the lug wrench in case they decide to bind too much for the lug wrench (same one I use to set the WDH) and roadside assistance if all else fails.
Also visibility equipment (triangles, flares, orange vest) rain gear (because that is when it will happen if I don't have it) and a plan in place with the rest of the crew as to who does what and how if an issue arises.
Finally, a good spare. I check all five tires before a long drive for pressure, rot and any other issues (wasp nest in the spare cover can be a real surprise during a trying situation).
2011 PrimeTime Tracer 2600rls
Arefbee is offline   Reply With Quote
Old 03-06-2014, 05:11 PM   #34
I have a 2014 forestriver Hemesphere TT, 36 total ft. dual axle, don't know what kind of supension I have.
Old 03-06-2014, 05:16 PM   #35
Ford Idaho's Avatar
Better to have it!
Besides for the price what the hay.
20 Ton Low Profile Hydraulic Bottle Jack
tire, tires
