Old 06-23-2016, 08:23 PM   #1
Geno
Flat towing
Has anyone encountered any issues when towing a full size vehicle mainly a 2016 Chevy Tahoe that has the electronic crash feature on it. after we disconnect from the blue ox system we are getting messages coming up with Automatic Collision prep unavailable, Front radar blocked. any help you can provide would be great.
allman is offline   Reply With Quote
Old 06-25-2016, 09:56 AM   #2
Are you pulling the negative battery terminal? Also on some models with the look ahead features are not flat towable. Not seeing anything like that on the FMCA page but I would double check the owners Manual.
Old 06-25-2016, 10:28 AM   #3
dan-nickie's Avatar
Soom bars can be used with the system and some can't. Do you know that yours is designed to be used with the Collision system? Have you check to see what's blocking the front radar?
Dan
2014 Berkshire 390RB-60
dan-nickie is offline   Reply With Quote
Old 06-25-2016, 10:35 AM   #4
Dan would pulling the negative battery turn off the radar? FMCA towing guide says to pull the battery cable.
Old 06-25-2016, 11:18 AM   #5
dan-nickie's Avatar
I'm not sure Phil. Even though the directions for my truck say to disconnect the battery, some base plates indicate they still will not work.
And I think OP is Saying after he disconnects his tow bar something is still blocking the radar. I think his base plate is blocking the sensor all the time.
Dan
Old 06-25-2016, 11:25 AM   #6
Gotcha. I thought it was a left over fault from have been towed with the cross bar.
Old 06-25-2016, 12:07 PM   #7
Failure is my business
2Evil4U's Avatar
Depending on the sensor view angle, possibly even a small bracket to the side of the emitter could cause an issue. Not sure, just a thought.
Current vehicle list: 17 RAM 3500 4x4 Cummins Aisin 4.10, 16 Flagstaff 832IKBS, 14 RAM 1500 4x4 Hemi 3.92 Bilstein 5100's Derale oil cooler, 97 F150 4x4 5.4L 259,000 miles, 80 Firebird Esprit Aussie Burnout Car https://youtu.be/v06VjII7HmE, 78 Harley Davidson FX 79,000 miles dad bought new, 71 El Camino ZZ3 TH400 12-Bolt, 37 Ford 3 window 502 Chevy dad built
Days Camped: 2016: 43, 2017: 83
2Evil4U is offline   Reply With Quote
Old 06-25-2016, 02:50 PM   #8
Geno
flat tow
GM says the Tahoe can be flat towed so we are good there. We disconnect the battery prior to flat towing. GM has realigned the sensor as well as replaced the module on the vehicle. Before they replace the module the automatic collision prep as well as the front señor block light would come on all the time. Now it intermittently. Which has GM and blue ox scratching there head as to what causing it. So my question is there anyone that has a Tahoe or vehicle similar that has encounter this problem.
towing
