Old 07-12-2016, 07:38 AM   #1
Mikes92's Avatar
Flat towing ?
Hi all, I am setting up a Ford Focus to flat tow. 2 questions: What suggestions does everyone have on supplemental brake systems? And on the Focus it calls for disconnecting the battery ground, do I need to be concerned with battery drain if using a system that requires power like the Blue Ox Patriot brake?
2015 Pursuit 33BH
New Jersey
Mike S
2015 Pursuit 33BH
New Jersey
Mikes92 is offline   Reply With Quote
Old 07-12-2016, 08:39 AM   #2
I am using the Blue Ox Patriot on a Honda CR-V and like it so far. I did have to dial the sensitivity down because it was breaking harder than I wanted it to. It does require power so I don't think you want to disconnect your car battery. On my Honda, the shop that set it up for me put in a kill switch to the trip computer and radio which would be a battery drain. I have towed up to 7 hours so far without any noticeable affect on the car battery. There may be a fuse on the Focus you can pull to stop some battery drain too.
2014 Sunseeker 2860DS
gmacklem is offline   Reply With Quote
Old 07-12-2016, 03:30 PM   #3
Buddymiller's Avatar
I'm towing a Jeep Wrangler behind Sunseeker MBS using InvisiBrake. Couldn't be happier works great.
Buddymiller is offline   Reply With Quote
Old 07-12-2016, 05:18 PM   #4
I've used a Brake Buddy for 7 years with no problems. It does require power. If worst came to worse you could simply rob power from the TV.
04 Ram 3500
07 Ram 3500
2011 Puma 295kbh
larryo is offline   Reply With Quote
towing
