Old 04-20-2011, 08:07 AM   #1
dretired's Avatar
Flex fuel savings ??
My local television station ,had a story about saving money using flex fuels .It was reported that if you fill up at the 1/2 way mark , switching from reg unleaded, to E85 and back . you would still get the mpgs that reg unleaded would give , and save some cash every 1/2 a tank fillup
dretired is offline   Reply With Quote
Old 04-20-2011, 11:08 AM   #2
Anacortesians
Don't think so. Ethanol has a lower calorific value than gasoline, and I think also has a lower specific gravity. The number of BTUs per gallon will be quite a bit less than gasoline, so you'll get less miles per gallon from the ethanol mixed in your tank, assuming similar combustion efficiency.
Frank and Eileen
No longer RVers or FR owners
Old 04-20-2011, 04:31 PM   #3
dretired's Avatar
Flex fuel ??
Seems to me i saw somewhere octane rating for E85 was 100-105. I filled my 2010 F150 with E 85 and got 17mpg at 60 mph.. not too bad..saving about 80 cents a gallon
Old 04-20-2011, 05:21 PM   #4
dretired, what kind of mileage do you get with regular 10% ethanol?
There has to be a savings using E85, otherwise there would be no point.
Old 04-20-2011, 05:29 PM   #5
dretired's Avatar
flex fuel
crocos, around 18-20 mpg with 10% ethanol
Old 04-20-2011, 05:39 PM   #6
donjuanss's Avatar
Had my local Service Manger at my dealer ship tell me he tried it on his 1500 Silverado and it dropped his mpg 5-6 mpg not much savings in my book.
U.S. Army Retired Desert Shield/Storm Vet
2014 Silverado Crew Cab
2009 28ft Flagstaff V-Lite
1996 Impala SS 1972 Chevelle SS
donjuanss is offline   Reply With Quote
Old 04-20-2011, 05:59 PM   #7
dretired's Avatar
flex fuel savings
When i filled my 2010 Ford f150with E85 the diffrence was 80 cents ($3.05 ) a gallon vs regular unleaded (3.85 ),on the way home i did 55-60 mph and got 17 miles per gallon
Old 04-20-2011, 06:03 PM   #8
You can't just run E85 in a normal engine. It has to be rated and set up to run the flex fuels.
2011 Ram Laramie
2010 Rockwood 8319ss
2010 Polaris sportman 300(wife's)
2005 Polaris sportman 500HO (mine)
trailraider is offline   Reply With Quote
Old 04-20-2011, 06:26 PM   #9
dretired's Avatar
flex fuel ready
yes, my 2010 F150 is flex fuel ready
Old 04-20-2011, 07:05 PM   #10
what would your truck normally get for milage?of it is close to the 17 it might be worth calculating to see if it is worth running E85. I have never run E85 so I have no comparison.
2011 Ram Laramie
