Just blow the antifreeze out of the system anytime you want including minutes after you pumped it in the system. You can flush it with very little water later, in warmer temperatures.
Winterization of the water system is removal of water. Antifreeze does this, of course, but once the water is out there's no need for antifreeze. Empty plumbing will not freeze.
-- Chuck
