Old 10-23-2011, 10:06 PM   #1
Foam under fresh water tank...
My used motorhome came without a fresh tank and pump. They had been removed. Previous owner used MH as a hospitality vehicle with no water system. I am adding them back in. Would it make sense to put a piece of 1/2" thick styrofoam under the tank? Would this help prevent pressure points and possible stress fracture/leak? Is there any special way to make sure the tank does not slide around? I will be using a 30 gal Barker tank. I will be placing the tank under the bed in the back bedroom.
turbosek is offline   Reply With Quote
Old 10-26-2011, 01:42 PM   #2
TURBS's Avatar
support anywhere is always good ! use metal straps to hold it down but use something between strap and tank to buffer . rubber ?
Old 10-26-2011, 11:11 PM   #3
flyrotor's Avatar
I think the styrofoam will break apart rather quickly, use rubber as f1100turbo suggested
flyrotor is offline   Reply With Quote
