07-05-2016, 11:59 AM
FR-1 water filter
Has anyone had leakage problems with their water filter? Ours was tightly screwed in (using the tool provided) and dropped off the cap causing flooding. Has anyone else had this happen to them?
07-05-2016, 12:14 PM
Give this a try. Lots people!
Let me google that for you
B and B
07-05-2016, 12:25 PM
Pull the filter assembly out and throw it away. It will, at best, just leak. A lot of these are blowing apart and flooding everything. Not to mention the filter replacements cost way too much.
2019.5 Rockwood 2509S
07-05-2016, 12:32 PM
I had to undo the glass filter container while it was fully charged to put the water filter in luckily I remembered to unscrew the drain cap in the bottom compartment when the water went everywhere
Rob & Elizabeth Sweeney
Having fun in our Forester Gump (2015 3051S forester)
07-05-2016, 01:00 PM
Originally Posted by B and B
I read this thread not because I have a leak at my filter, but I was trying to lock away some knowledge in case I ever did have a leak.
But now I am confused by the intent of this reply and the attached link. When I clicked the link, it took me to Google web site. Are you implying I should trust the responses in Google more than the responses of FRF members?
Thanks for the question and helpful replies.
07-05-2016, 05:49 PM
No leaks but I removed it from under the counter where it was hard to get at and moved it outside. I hook it up when I get to the campground. When I purchased our RV, 12/13, the dealer gave us an extra six filters. When those are gone so will the entire assembly be gone, a HD type will be used. Three down three to go.
Joe & Beverly
2014 Ram 2500 CTD, CC, SB
2014 8289WS lifted
07-05-2016, 10:08 PM
If you do a search in this forum, there is no shortage of people who have experienced leaks, many have had major leaks that have caused a lot of damage, caused by the canister completely letting go. Many of us have totally removed the filter and placed a filter outside.
2016 Chevy Silverado 2500 Duramax
2016 Rockwood 8289WS, Diamond Pkg.
07-06-2016, 06:33 AM
Did you try putting plumbing tape around the thread
2019 Flagstaff 26 RBWS
2015 GMC Sierra 1500
2019 camp 17 nites. Bill,Alley and are two kids Sierra,Ivy. 2020 camp 9 nites
07-06-2016, 06:43 AM
FR-1 water filter
If you tightened it tight with tool that was your problem!
You tighten it by hand and line up the arrow!
This one shows over tightened.
2015 Columbus 320RS
2008 2500HD Duramax
2015 nights camped "34"
2016 nights camped "10"
07-07-2016, 02:34 AM
Yes, I have. Twice. Doesn't take me long to figure things out...
2015 Forest River Rockwood Signature Series Ultra Lite 8289WS w/Diamond pkg.
2014 RAM CTD 6.7 Tradesman 4WD Auto Crew Cab Long Bed
Honda eu2200i generators
07-07-2016, 10:35 AM
Actually, the link includes responses from FRF. Although it's much easier to just use the built-in search function at the top of the page. This is a pretty common question/problem.
07-07-2016, 11:32 AM
You'll not have any issues with this filter and housing as long as you use it correctly.
2015 Columbus 320RS
2008 2500HD Duramax
07-09-2016, 02:08 AM
X2 with TURBS response. I have heard a lot of complaining about this filter system. I will agree it is different from the waterpur in our 09 Cardinal but I am just careful removing and tighten.
2019 Ford F-250 6.2l gas 430 E Lock
2015 Cedar Creek 34RL
MORryde IS 7000 LB
Kodiak Disc Brakes
07-09-2016, 09:25 AM
If done right water filter canister should screw off by hand or very little effort from the wrench
2015 Columbus 320RS
2008 2500HD Duramax
2016 nights camped "14"
07-09-2016, 10:00 AM
This is the easiest way to provide all the links to water filter questions and good answers on the FRF.
B and B
07-09-2016, 10:02 AM
The plumbing tape would prevent proper tightness. The O ring will seal just fine.
B and B
07-09-2016, 06:48 PM
Agreed. No need to use plumbers tape. Plastic to plastic- no tape.
07-09-2016, 07:05 PM
The sealing is done by the o-ring, try cleaning the mating surfaces for the o-ring and apply a light coat of fauset grease to the o-ring
07-09-2016, 07:48 PM
Mine works great had it for 3 years. The key is not to over tighten, and do not us the wrench to tighten. Hand tight to snug only.
2014 cedar creek 36ckts
2014 Chevy 3500 1 ton crew cab 4x4 long bed.
07-09-2016, 08:10 PM
I pretty much agree.
2015 Columbus 320RS
2008 2500HD Duramax
