Old 08-20-2016, 11:36 AM   #1
jonrjen's Avatar
Freezer and Frig temp averages
I have the basic Dometic LP/Electric frig/freezer unit in our Wildcat.
I am wondering what your average temp runs in each on your unit? Is there an average or does the range vary greatly.
I just checked ours, it's been on for approx. 24 hours. Our outside temps are extremely low right now in the mid 80s with very high humidity right now.
The frig was at 38 and the freezer at 32 degrees.
I just raised the cooling sensor to see what I can get it down to. It is currently on Electric power.
Thanks for your impute.
2013 Ford F350 FX4 4x4 PSD
2013 Wildcat 353LS
2015 Day/Nights Camped 5
2014 Day/Nights Camped 29
jonrjen is offline   Reply With Quote
Old 08-20-2016, 06:16 PM   #2
We have a Dometic RM2351 that gets down to -2 in the freezer and 30 in the refrigerator on electric. When on gas though, it is mid 30's in the freezer and mid to upper 50's on propane.
John & Mary Jo
Enjoying the adventure
Ky-N is offline   Reply With Quote
Old 08-20-2016, 07:59 PM   #3
indybp57's Avatar
Our fridge stays around 29-32F on electric, about 32-35 on propane when traveling. Never checked the freezer but the ice cream gets pretty hard.☺
Sent from my 9020A using Tapatalk
2013 Roo 183
2012: 1042 Miles, 13 Nights camped
2013: 2772 Miles, 27 Nights camped
2014: 2259 Miles, 30 Nights camped
2015: 1644 Miles, 20 Nights camped
2016: 550 Miles, 11 Nights camped
indybp57 is offline   Reply With Quote
Old 08-20-2016, 10:31 PM   #4
I remember a camper from the 90's I had seemed to stay colder on gas. But my slightly newer unit seems to run colder on electric. So I think it's model dependent.
Motofixxer is offline   Reply With Quote
Old 08-21-2016, 06:06 AM   #5
Head Rambler
DM2652
On Electric
Fridge = 32 - 36
Freezer = 3 - 9
On Gas
Fridge = 34 - 38
Freezer = 4 - 10
These temps have been taken during 90+ outside temps and with the A/C both on and off in the RV, over a period of several weeks.
Salem 29RKSS Pushing a 2500 Mega-Cab CTD!
Gotta go campin!
Old 08-21-2016, 12:37 PM   #6
I seem to average 34-36 in the fridge and 10-0 in the freezer whether I'm on gas or electric and whether it is the winter in Nashville or summer in Southeast Texas. Nice and consistent for now. Of course, I limit how often I open the unit and I'll sometimes run an air circulator in the fridge in the summer.
_____________________
Berk Thompson
TT 2013 FR V Lite WIKSS
TV 2013 Chevy 2500 Crew Cab
Middleburg Redneck is offline   Reply With Quote
Old 08-21-2016, 12:53 PM   #7
Location: Full timer,,,at Lake Georgetown in central Texas for the winter.
Something else to consider.......is your fridge in a slide out? If so, you have side ports outside for the heat to escape. It's harder for the system when you have that type. I live in central Texas and mine is in a slide. I added another condenser cooling fan in tandem with the original one outside and it's really helped with the cooling of the fridge in hot summer Texas. My temps are usually 4 or 6 in the freezer and 32 to 34 in the fridge.
Grampa Jim is offline   Reply With Quote
Old 08-21-2016, 12:59 PM   #8
I believe the QC is so poor in the fridge factories that different units of the same model will vary in performance. Some folks add fans, it helps some, others it's no help.
I replaced with 9 cu ft electric will add inverter soon. During replacement saw signs of impending fire in cabinet over flue, 2016 model.
2016 Flagstaff 27VRL with overloaded tires from factory
2015 Chevy Silverado
Paul GA is offline   Reply With Quote
Old 08-21-2016, 01:28 PM   #9
I was going to start a thread on this today so your timing is great. I have been monitoring my fridge temp's on various setting at different outside temperatures. I just had the fridge checked by my dealer and they indicated it was within specs using setting 4 and on gas. Basically near 37 in fridge and 2 in freezer. I think they must be checking first thing in the morning. I have a 2015 Cedar Creek Silverback with the fridge in slide. I don't know the model of the fridge. Here is what I am experiencing in my testing of the fridge (not freezer) while the RV is parked under a protective cover and using electricity:
57 deg on setting 3 with outside temp high 90s
45 deg on setting 3 with outside temp low 80s
50 deg on setting 4 with outside temp 97 degrees
37 deg on setting 4 with outside temp 63 degrees
31.5 deg on setting 5 outside temp 62 degrees
Will check again this afternoon when hot outside.
Needless to say, I do not consider this acceptable when hot outside and don't know whether I need a replacement unit or if it can be fixed.
modem9 is offline   Reply With Quote
Old 08-21-2016, 01:50 PM   #10
Gas or electric should give you temps in the low 30's and single digits. Anything else? There's a problem,,,even with ambients in the 80's and 90's. Consider adding a fan to cool the condenser fins more. My temps were in the 40's and 50's and freezer in the teens at best. I had an ammonia solution clog at a mild kink on my condenser line and it didn't manifest itself until the thermal switch stayed open and overheated everything. That was a fun time figuring that one out. But I tapped the kink with a hammer several times,,,knowing there was a restriction since it was hot on one side and much cooler on the downside.
