Old 04-17-2016, 01:16 PM   #21
We take gallon water jugs filled with water from our purified water faucet to use for cooking, drinking, etc. When all are empty we just go to Meijer Thrifty acres or Walmart, take in our empty jugs, and fill up there for a minimal cost.
rogerkathy is offline   Reply With Quote
Old 04-18-2016, 11:20 AM   #22
Tom48's Avatar
Originally Posted by Myrle View Post
If the water has clorine it will start smelling in 4 or 5 weeks.
Pool professionals or water system technicians can tell you better, but my memory says, if you smell chlorine then it is oxidizing bacteria. That's good, cause that's what it's supposed to do. But bad because it means you either have way too much chlorine , , OR bacteria is growing in the tank and it might be a good idea to sanitize the system.
We have really good water St home so I load up with, chlorine and all. Traveling if I fill up I use a really good filter. Better to be sure the bad stuff is not joining us even though I know that the filter is removing the chlorine too.
Tom48 is online now   Reply With Quote
fresh water, water
