Old 07-02-2019, 01:10 PM   #21
Dobbs from WI
Last trip we were connected to the campground water and the DW complained about the pressure of the shower (Oxygenic). I put water in the fresh tank and the next shower we disconnected the hose and turned on the pump. Shower #2 was much better. Found out by talking to others that they thought the pressure at the campground was low. I agreed with that assessment.
Dobbs is offline   Reply With Quote
Old 07-02-2019, 01:14 PM   #22
Originally Posted by Bilcin View Post
Thanks for all replies! The water flow throughout the trailer is low. I will be trying a new shower head/ removing flow restrictor. I always camp with full service.
Have you tried the water system using the pump? (city hose disconnected & using water in fresh tank) That would eliminate most of the other possibilities talked about. (supply hose diameter, regulator restriction. filter restriction, etc.)
Days Camped '19=118 '20=116 '21=123 '22=134 '23=118 '24=90
Old 07-02-2019, 08:15 PM   #23
Bilcin's Avatar
I have, and there was slightly more flow, I think the shower head is the problem. I am going to try the one that was recommended by multiple posters.
Bill & Cindy McKenna
Philadelphia PA
2015 Palomino Puma 32DBKS
2005 Ford Excursion 6 liter Turbo Diesel
Bilcin is offline   Reply With Quote
Old 07-08-2019, 01:54 PM   #24
Bilcin's Avatar
Up date!!! I bought a PIH shower head (just like the Oxygenic) for $15 on Amazon. Old shower head sprayed water out approximately 3-4 inches. The PIH sprayed water out to the other side of my 3 angled shower. The difference is night and day!!!!
Philadelphia PA
fresh water, water
