Old 07-14-2015, 02:04 PM   #11
I roll it up on one of these reels from Home Depot:
Just have to squeeze the hose flat a bit to get it hooked in at the start.
Loraura is offline   Reply With Quote
Old 07-14-2015, 02:29 PM   #12
Old car's Avatar
Rolled up and held together with Velcro. I carry 75 foot of hose (all 25' lengths) them in a small plastic tote with secured cover. Just pull out one lenghth at a time or more if needed.
Randy and Patty
2015 Sabre 33 CKTS-6 Platinum Edition
Reese 16K Slider hitch
2015 GMC Sierra 3500HD diesel dually
Old car is offline   Reply With Quote
Old 07-14-2015, 02:57 PM   #13
jeff64's Avatar
My experience with the flat hose( mini fire hose) is they don't hold up well and are prone to springing leaks after a year. These are like what CW sells on a windup reel? yes?. Valtera makes a white/ blue stripe hose that collapses pretty flat and can be wound up on a flat cord keeper that I think I'm on my 3rd year with. You might check it out on Amazon
Old 07-14-2015, 03:09 PM   #14
Georgia Frog Rally 2018
aceinspp's Avatar
X5 I use the wire wrap that came with the hose to tie the hose. Later RJD
2015 Chevy 2500 6.0 4:10 gearing.
Days camped in 2016 58
Days camped 2017 62
Days camped 2018 18
Old 07-14-2015, 03:14 PM   #15
BamaBob's Avatar
Originally Posted by OldCoot View Post
Here's what I did. Haven't tried the flat hose for extended periods of time, so I will carry the regular hoses this winter in FL and if the flat hose works, will get rid of the regular hoses next spring.
now THAT is a great idea OC! Keep us posted on how the flat hose works for you - if it works well that will be the end to one of the most unwieldy things I have to pack (#2 is that &%$! 50 AMP cord! )
Nights Camped: 2013 - 24 2014 - 42 2015 - 56 Jul 2016 - Fulltime
BamaBob is offline   Reply With Quote
Old 07-14-2015, 03:29 PM   #16
Sounds like everyone screws the 2 ends together to keep the inside sanitary which is what I was doing. Just wasn't sure if I was growing mold also. Thanks for all the quick replies. I think I need some Velcro straps too.
Dan Sundt is offline   Reply With Quote
Old 07-14-2015, 03:45 PM   #17
thetanu539's Avatar
I roll mine nicely (a little OCD), screw the ends together, strap with velcro, and store in a small round wreath storage bin in the front pass through compartment.
Randy
14 PT Avenger ATI 27BBS
09 Nissan Armada
Central Ohio
thetanu539 is offline   Reply With Quote
Old 07-14-2015, 05:28 PM   #18
Fulltime family RVer
Since I've been going directly from one campground to the next, I've stopped rolling up the 50amp cord and instead sort of roll it and then throw it into the back of the truck. It's my greatest guilty secret.
ependydad is online now   Reply With Quote
Old 07-15-2015, 11:40 AM   #19
widogmom's Avatar
Originally Posted by steveh326 View Post
I drain the hose and screw the ends together. never had an issue so far.
Yep, exactly...then put it in a plastic tub from Ace Hardware that I keep clean. Fill gizmo wrapped in paper towels in my clean dishtowel drawer.
2015 Sunseeker 3010DS
2005 Honda Element (toad)
Now, Voyager, sail thou forth, to seek and find.
widogmom is offline   Reply With Quote
Old 07-15-2015, 12:03 PM   #20
To organize my hoses, cords and tools, I purchased a 3-pack of these Rubbermaid Cargo bins at Costco.
Cargo Bin | Rubbermaid
They fit perfectly in the my storage area under the bunks in my Flagstaff 23LB. Each one holds quite a bit and they have rubber feet for stability and solid bottoms so any spilled liquids are contained.
FYI, I drain and couple my hose ends when storing. No issues yet.
Chris D.
'09 BMW X5 xDrive35D (TV)
'05 Porsche Cayenne (Wife's)
'15 Flagstaff Micro Lite 23LB (TT)
MudyOvl is offline   Reply With Quote
fresh water, storage, water
