Old 06-12-2016, 02:03 PM   #11
Originally Posted by mjones12 View Post
Just a note about using surgical gloves: They defeat the purpose if you don't know the proper way to remove them from your hands. There's a wrong way and a right way. If you don't know, ask a nurse to demonstrate.
No thanks......
I associate those gloves with a certain uncomfortable and awkward procedure. Funny how it never was an issue until I seen Jack Elam play a doctor in one of those Smokey and the bandit movies. Ever since I have had Elamphobia....fear of surgical gloves.
Mr Havercamp is offline   Reply With Quote
Old 06-12-2016, 02:13 PM   #12
Croaker's Avatar
Originally Posted by Mr Havercamp View Post
Its not like the bacteria can crawl out of your slinky and walk on over and jump into your water hose......
It hurts. It hurts....laughing too hard.
Croaker is offline   Reply With Quote
Old 06-12-2016, 02:18 PM   #13
BandJCarm's Avatar
It would be nice if they were further apart.
But..........my house has all the plumbing close together.
and I wash my hands.
FROG AR-0019-242
BandJCarm is offline   Reply With Quote
Old 06-12-2016, 02:26 PM   #14
Get a spray bottle and make a water bleach mixture. Before you do any freshwater connections spray the fresh water faucet and handle with the mixture. Just remember, the last guy there may have finished his black tank bidness then without washing his hands disconnected his freshwater.... Hmmmm...
2016 Siverback 33IK
2015 Ford F-250 Lariat 6.7L V8 Diesel 4WD Super Cab
Old 06-12-2016, 06:40 PM   #15
Maybe I made my concern sound a little stronger than I really worry about this. I just think about it when I'm sitting with my coffee looking at backside of next camper and see the white hose draped over sewer lines. Just funny after reading threads on here about 10 step processes for dumping, procedures to maintain hose such as putting ends together when not in use...etc...etc... Don't worry...I'm not that weird guy who sometimes camps next to you. Well...I might be but not for this reason.
srderby is offline   Reply With Quote
Old 06-12-2016, 06:53 PM   #16
By International Plumbing Code all sewer lines and potable water lines shall be 12 inches apart and 12 inches above or below each other
Boohiney is offline   Reply With Quote
Old 06-12-2016, 06:58 PM   #17
Does that happen in the real world..NO but that is the code.
There really isn't much to worry about as long as sanitary procedures are used
Old 06-12-2016, 09:27 PM   #18
I fully understand the concern voiced about the potential for cross contamination between sewer and fresh water hoses. However, a well thought-out and practiced standard procedure should remove any potential for contamination. We keep all fresh water hoses and fittings in a separate container from the sewer hose and fittings. When we arrive at site, we hook up and test the fresh water connection before even touching the sewer hose container. We often never even connect the sewer hose until we are ready to break camp at the end of our stay. Before we do so, we disconnect, flush, and stow the fresh water hose and fittings in their own container. We then don vinyl gloves before handling the sewer hose and fittings, hook it up, and then connect a separate fresh water hose to use to activate the on-board flushing attachment in the black water tank. We dump the black waste water first, then watch through a transparent fitting until the outflow from the black water tank shows clear. We shut off the flushing hose, wait until there is almost no more water flow, then open the drain valves from the grey water tank(s) until they are empty. We shut all drain valves, disconnect the sewer hose and flush with fresh water from the separate flushing hose, then drain as best we can before stowing back into their separate containers. Finally, discard the vinyl gloves, wash our hands, and wave goodbye.
Jakie-Boy is offline   Reply With Quote
Old 06-12-2016, 09:37 PM   #19
BamaBob's Avatar
Originally Posted by srderby View Post
Has anyone else wondered why the sewer and water intake are so close? It always bothers me to have my white hose so close to the sewer hose. I try to keep it off the ground and as far away as I can but...always too close. Though I'm meticulous with me flushing and dumping I'm sure that over time there have been spills in the area. Am I too bothered by this? Anyone have any tips?
Intake? You have a sewer INTAKE?
Don't worry about it - you are fine. Put your FWH and filters in and your sewer dump where it is. Just keep everything clean with wipes and you are fine!
Nights Camped: 2013 - 24 2014 - 42 2015 - 56 Jul 2016 - Fulltime
BamaBob is offline   Reply With Quote
Old 06-12-2016, 09:46 PM   #20
B and B's Avatar
I find it funny reading these threads. I dump my tanks with no gloves, using the cheap freebie slinky. Black/ Grey then Galley Grey. Oh yes this is after camping for week on all tanks in the summer!
I do not get my hands dirty at all.
2017 Heartland Bighorn 3575 Elite with Reese Sidewinder
2016 Ford F 350 SD PS 6.7 SRW Crew Pucks and Reese 18 K Elite
2013 Rockwood 8289WS 2012 Rockwood 2703 SS TT 2007 Golden Falcon 38FLA PM 1983 Corsair 21RB
2015 Ford F250 PS '13 F150 3.5 Eco '09 F150 5.4 l 1987 Merc Grand Marq 1982 Ford E250 CW
fresh water, water
