Old 02-04-2015, 09:56 AM   #1
Freshwater vent clogged??
I noticed when I was dry camping several weeks ago, that when I tried filling the freshwater tank, it would not fill all the way. Water would come out the fill tube but indicator light only says 2/3rds. Also in past, I always heard a rushing or whistling sound as it was getting near full but now I don't hear a thing leading me to believe the vent's clogged? I know for a fact it's not full as I don't get near the water usage out of it.
If so, how can I unclog? there is a screen over the vent and i'm reluctant to poke a hole in it. Any suggestions?
boatnut is offline   Reply With Quote
Old 02-04-2015, 10:12 AM   #2
Compressed air, 30-40 PSI . Have had the same problem,
Kevin & Judy is offline   Reply With Quote
Old 02-04-2015, 10:21 AM   #3
Empty tank first?
Old 02-06-2015, 06:34 PM   #4
That hose has a compression fitting if you are to get a hand on it. Then compressed are or a piece of tubing slid down the length. Thing is what clogs a fresh water hose inside a TT? possibly twisted or collapsed on itself from the pump? Doubt a mouse/bugs/small bird etc would get down there to clog it.
tenttotrailer is offline   Reply With Quote
Old 02-06-2015, 06:47 PM   #5
mark0224's Avatar
Open fill cap too so you don't blow it off
Think about things before you do them make life easier not harder.
mark0224 is offline   Reply With Quote
Old 02-07-2015, 09:13 AM   #6
zs325RES's Avatar
Same as Ken & Judy
I found that water gets into the vent hose and stays there because of a dip in how it's routed from the tank to the vent. It will then not allow air past and I couldn't fill past 2/3 tank
I made a small tube with a rubber fitting that fits tight over the vent screen and I just blow back into it to clear the water out. My tank will fill right up after doing this
2013 Crusader 325RES Touring Edition
2006 Silverado 2500HD LT SW ECSB, 6L LQ4/4L80E 4.10s w/16K Curt slider (not necessary), Air Lift bags & Black Bear Performance tune & CAI
Norm & Karen Zondervan
zs325RES is offline   Reply With Quote
vent, water
