Old 05-31-2012, 01:17 PM   #1
Fridge concerns
My Dometic fridge does not seem to be working on electric power, even after being plugged in for several days. Do these fridges use refrigerant and if so, can it be recharged?
Stevelitt is offline   Reply With Quote
Old 05-31-2012, 02:20 PM   #2
papap's Avatar
They use ammonia.
2016 Forester 3171DS
Work 28 and 28 around the world.
Camp every chance we get
papap is offline   Reply With Quote
Old 05-31-2012, 02:27 PM   #3
How do you refill?
Old 05-31-2012, 02:30 PM   #4
papap's Avatar
That I have no clue. I'm sure a camper service tech can do it. But if it leaked out. There must be a hole in system somewhere. This is not a high pressure system like on other AC units. There is no compressor unit.
Old 05-31-2012, 02:47 PM   #5
First things first. Does it work on gas? If it is in fact dead you should have smelled amonia sometime. If it is dead then the only remidy is a new refer or a new cooling unit.
Old 05-31-2012, 02:52 PM   #6
I am planning on trying it on gas next time I pop up. It was not acting right last trip out and thought perhaps it was because food wasn't chilled to start with, but was put in right after coming from store.
No smell of ammonia...
Old 05-31-2012, 02:53 PM   #7
MtnGuy's Avatar
If the fridge works on propane, then it is not the refrigerant.....both gas and electric heat the same refrigerant.
1st, pull the outside cover and make sure the fridge is plugged in. Might want to check the plug with a tester to make sure you have current there. If no current there, then check the breaker to make sure that is on.
If that does't work, let us know and we can go from there....at least someone will, as that is about the limit of my fridge knowledge.
Old 05-31-2012, 03:08 PM   #8
The unit heated up, but did not cool down inside the fridge, so that is what led me to think it was messed up.
Old 05-31-2012, 03:09 PM   #9
MtnGuy's Avatar
Does it work on propane ??
Year and model of camper ??
Old 05-31-2012, 03:40 PM   #10
I had a situation on our last camping trip where the unit stopped cooling on AC. I verified that the outlet was getting power but since I did not have any wiring diagrams or troubleshooting tools with me I switched it to propane and it worked fine. When I got home on Monday, I downloaded the wiring diagram and found that my DC power terminal block had some screw down terminals. I tightened those up and all has been good ever since. I should mention that the AUTO light was not illuminated prior to finding this. Since finding it, the light is on and the unit is cooling properly.
mrmurph is offline   Reply With Quote
