08-04-2017, 06:06 PM
fridge on battery
My Windjammer is stored in a storage lot at a local campground. I would like to load my fridge the night before. I have no power to the camper unless I rent a site the night before and turn on the fridge let it cool and then load it. My question is, could I run my fridge on 12 volt the night before then load it in the morning. I know propane usage is minimal , how about the 12 volt ? Would that last overnight without depleting the battery. I run a single battery rv/ marina type deep cell. Battery maintains a full charge via small solar panel. I have been keeping my food in a cooler, turn on the fridge after I hook up, I will usually be able to load my food in the fridge after I arrive at the campsite. The last option works, but how long can the fridge run on 12 volt power before running down the battery? 24 hrs? I know you boon dockers have it down to a science.
Chuck " still in Va "
2012 3065w Windjammer
2012 f250 lariat Crew cab power stroke (of course )
08-04-2017, 06:09 PM
I start our fridge the night before we leave and haven't had any problems, I also have 4 fans on the fridge that I leave on also.
2006 2500HD CCSB 2WD 2014 Crusader 285RET
Nights camped in 2013 - not enough!, 2014 37, 2015 40, 2016 39, 2017 38, 2018 36, 2019 37, 2020 26, 2021 28
08-04-2017, 06:30 PM
I depends on what you mean about running on 12 volt.
The refrigerator on propane with 12 power on to the control board will go 2-3 days on a healthy 100 amp hour battery. Most coaches will draw 18 to 25 amp hrs per day as a baseline which includes fridge on propane.
If you are referring to using a 3 way fridge, set to 12 volt , with one battery then you may not make 6 hours powering the 250 to 300 watt heating element that evaporates the ammonia solution .
Hope that helps. Good luck
2015 Solera 24r
2017 Jeep Wrangler
08-04-2017, 06:35 PM
Run your fridge on propane, power draw is approx .8 amps when fridge is in cooling mode. So running for 12 hours would use approx 8 amp hours for power.
2007 Surveyor SV230 - 200 Watts Solar/MPPT Controller - 220 AH Battery Bank (Two-GC2) - 600 watt PSW Inverter - (2) 2000 watt Inverter Generators - LED Lighting
Boon Docking 99% of the time.
08-04-2017, 07:05 PM
King of the Road
Agree, propane is the way to go. Many of the new 3 way refridgerators are really only propane and 120, with the 12v setting going through an inverter to generate the 120v from 12v.
That would draw down your battery even faster. Since I don't know the model, can't say if yours is like that, but you should check.
2016 Crusader Lite
Single slide
2013 Ram 2500 Crew Cab Tow Vehicle
2016 days camped = 91, 2017 days camped = 109
08-04-2017, 07:15 PM
Location: Minnesota ( wishing we were boondocking in the New York Catskills )
Consider loading it with a couple blocks of ice, or add some frozen jugs of water from your own freezer or deep freeze ... over night, that would pretty much pull the box as far down as it will go, pull out the ice before AM departure if you need last bit of space for additional food load. Start with propane in morning then, it develops the magic chemical cycle refrigeration way faster than the electric heating element.
Jeff and Abby
Fur Babies - Xandra Sophia (GSD) and Neo (Min-Pin Mutt who thinks he is a cat)
2015 Tracer Air 235 (previous 1994 Veri-Lite 1130 TC)
1998 Dodge Ram 2500 Quad Cab - 360 - 46RE (Built)
08-04-2017, 10:33 PM
Charles, your fridge is either 2-way or residential.
2-way only runs on propane or shore power. It uses 12v power for the electronics.
A residential fridge will run on battery power IF you have an inverter. But you'll need at least 2 batteries.
08-05-2017, 05:52 AM
I have a 2 way fridge. Its either propane or 120v. So when running on propane does it take much battery power to keep it going ? Lets say for 12 hrs without any hookups.
08-05-2017, 06:13 AM
You can run your Refer for 12 hrs on Bat/Propane "after it has been ON for12 hrs and Cooled Down"! Youroo! !
08-05-2017, 07:10 AM
Originally Posted by youroo
You can run your Refer for 12 hrs on Bat/Propane after it has been ON for12 hrs and Cooled Down"! Youroo! !
Not sure why you think it needs to be cooled down first??
I turn mine on LP the day before we load up all the time with no problems.
24 hours on LP even if they have the dreaded environmental heater between
the doors should not be a problem.
Happy Trails!
Peace!
Dan & Rita D
08-05-2017, 10:44 AM
