Old 04-23-2011, 05:42 PM   #1
dretired's Avatar
fridge operation
I thought the fridge should operate just with having the power cord plugged in (the one that comes out the back of the trailer.I turned the on button on and the check light came on after a while. i called a friend ,he said try turning onthe propane tank , light a burner on the stove to get air out of the line. then try the fridge on auto. It seems to be working fine but is it running on propane now or electricity ??
dretired is offline   Reply With Quote
Old 04-23-2011, 05:52 PM   #2
tmmar's Avatar
It sounds like it is running on propane. There should be a switch on the front, top of the fridge that allows you to select the mode (electric or gas) that it will operate in.
Tom and Margaret
2014 Berkshire 390bh-60
Old 04-23-2011, 06:16 PM   #3
DF5.4's Avatar
The switch may say "Auto" too.
Doug
2011 Prime Time Tracer 3000BHS
2007 Ford Expedition
Reese Dual Cam HP Hitch
Nights Camped 2015-5 in TT
DF5.4 is offline   Reply With Quote
Old 04-23-2011, 07:11 PM   #4
dretired's Avatar
fridge operation
Yes, the fridge is working in Auto..
Old 04-23-2011, 07:15 PM   #5
DF5.4's Avatar
Did you try turning the propane off and see if the check light comes back on?
Doug
Old 04-23-2011, 07:30 PM   #6
Herk7769's Avatar
The fridge will ALWAYS work on 120VAC if it is plugged in; regardless of the availability of Propane if the "on/off - auto" switch is on.
The check light will ONLY come on if there is no AC AND there is 12VDC available; the fridge is calling for cold; and the propane fails to ignite to ignite. (Propane off; control board failure; control board fuse failure).
If both are available, the AC is Primary. The Propane will light and the fridge will stay cold IF you leave the bottle on and the campground power fails.
HAM CALLSIGN - KC3FFW
Old 04-23-2011, 07:37 PM   #7
It took me a while reading the instructions on the freezer door to 'get it' so to speak.
As I remember when you push the left button 'in' and the right button is in the 'out' position the light will say 'Auto' and you are running on electricity.
Then, when you push the right button 'in' the 'auto light goes out and it will try to go to propane. After three or four times trying to 'start' the flame...if it has not igited...then it stops trying and the 'Check' light comes on. You then have to put both buttons in the 'out' position and start over.
It sometimes take two or three times doing this to get it started on propane...not a problem. As your friend said....you are 'purging the gas from the lines when you do the lines by doing the burner thing.
I usually get mine running on propane for a day or so before a trip to get it cold, then run it on propane going down the road. And no I don't worry about turning it off as gas staions when I fuel. Then at the campground I simply put the right switch in the 'out' position so it is running on electricity again.
Jack
2006 Flagstaff 831RLSS Travel Trailer
2007 Chevy 2500HD 'Classic' with the Duramax engine.
Converting a 1956 GMC PD4501 Scenicruiser, ex Greyhound into a motor home.
jackhartjr is offline   Reply With Quote
Old 04-23-2011, 07:49 PM   #8
My suburban fridge may be different, but it has two buttons; one is on/off, and the other is gas; on when out, off when in, and THEN the electric mode works. There is a light that illuminates when on, that says auto., and another light for check. I have had the outside control board fuse blow on the 120v AC side three times; my dealer said it was a bad ground connection on the board. Fixed now. Randy
Old 04-23-2011, 09:23 PM   #9
Herk7769's Avatar
Yes, you can "Force Gas" with the gas button. I neglected to mention that. If the "gas" button is "in", it will force gas ignition, regardless of AC power available.
If the gas is turned off at the bottle, you will get a "check" light, since the gas did not light.
Normal operation of the fridge is "Auto" - On "gas" - Off
That way it will default to AC if available and auto switch to gas if needed.
Old 04-24-2011, 05:02 AM   #10
dretired's Avatar
Fridge operation
Thanks every body !!! For the help , next,( Probably Monday ) i will try and fire -up the furnace & hot water heater, which i already have 2 questions.. #1 How do you know ..when to replace the sacrifical anedode rod ,for the hot water tank ?? #2 Some hot weater tanks are both electric and gas .. How does one tell ,if you have one of these ,or Propane only ??
