Old 02-14-2011, 02:38 PM   #21
great white's Avatar
Originally Posted by herk7769 View Post
Nice! Then you know that NONE of that aerodynamic discussion applies to you. Helicopters do not fly using principles of aerodynamics. They just BEAT the air into submission.
I prefer to think of it as a collection of loose parts flying together in a tight formation.....
2011 Flagstaff Classic Superlight 831RLBSS "Atrium slide"
Husky Centerline Hitch
2016 Ford F-150 EcoBoost SuperCrew, Lariat Sport, Max Tow package
great white is offline   Reply With Quote
Old 04-09-2011, 10:56 PM   #22
FarmerMT's Avatar
Just be glad you don't have a Hemi! I am off to get a second job so I can afford to pull my camper to the KOA on the edge of town! (1/8 of a mile away)
Phil, Michelle, Logan and Wyatt
2006 Dodge 2500 Heavy Duty 5.7 Hemi
2012 Rockwood 8312ss
FarmerMT is offline   Reply With Quote
Old 04-10-2011, 07:10 AM   #23
Wanna Be Camper
SaskCampers's Avatar
I pulled our 34' V-Lite 6000km last summer and got 11.2 average at 60mph with 4 people in the truck. On a good day with no head wind I can get up to 22 on the highway and generally get 13 to 14 around town.
John & Deb
2011 Flagstaff V-Lite 30WRLS
Days Camped 2016: 3 2017: 0
Old 04-10-2011, 08:11 AM   #24
Glenn5995's Avatar
Is that kilometers per imperial gallon (4.55L)?
The best I have ever got with my Power Wagon (5.7L Hemi powered) is 15.5 miles per U.S. gallon (3.79L). That is empty highway driving. Towing I average 8.5 MPG.
Glenn & Beth (Dad & Mom)
David & Audra (16 year old twins)
Glenn5995 is offline   Reply With Quote
Old 04-10-2011, 08:34 AM   #25
Wanna Be Camper
Miles per imperial gallon. So I guess for US just subtract 20% I think it is. Although in your trucks defence, the 4:56 gears probably have alot to do with it vs the size and weight of the Megacab with 3:73's.
John & Deb
Old 04-10-2011, 08:47 AM   #26
sherdep's Avatar
I run a Hemi with 3.92 gears and 35" all terrain tires - I average between 9mpg and 11mpg towing (doing 55)
without anything loaded I average 12mpg to 14mpg (70mph to 80mph) - I am also running superchips with the shift points so it allows me to change the tune of the truck so the computer is diffrent on each tune - the down fall to running the superchips is that I have to run super unleaded and with a 36 gallon tank it puts a hurting on the wallet
2011 Rockwood Mini Lite 2306 - Matt
2004 Dodge Ram 1500 Qaud Cab 4x4 with 35" tires and 3.92 gears, Dynatech Longtube Headers & Fabtech 6" lift + Superchips with shift Tuning
Nights Camped 2011 (37) - 2012 (16)-2013 (2) -2014 (5) -2015(0)
USMC 91 - 95 - F/A-18 Aviation Ordnance
sherdep is offline   Reply With Quote
Old 04-10-2011, 08:58 AM   #27
Glenn5995's Avatar
There are definitely many factors which effect MPG, such as gear ratio, weight and frontal surface area. I just was not aware of anyone with a Hemi 2500 getting 22MPG on the U.S. system. Just wanted to clarify.
Old 04-10-2011, 09:04 AM   #28
Glenn5995's Avatar
I get about the same MPG. I have a Hemi, 4.56 gears and 33" all terrains. I average 8.5 MPG towing ( I have more frontal surface area with a 5'er than you do with a TT), 11 MPG city, 13 MPG empty highway @ 75-80 MPH and 15 MPG empty highway if I stay below 65 MPH.
Of course none of this helps the OP with his CTD MPG concerns. Sorry for the hi-jack! We now return to our regularly scheduled topic.........maybe.
Old 04-10-2011, 10:33 AM   #29
prof_fate's Avatar
Diesels and/or properly setup up TVs don't lose that much MPG when towing from what I understand. Torque is what does the work (moves the load) and high gearing multiplies torque and diesels have loads of torque.
My expy (5.4 gas, 3:55, AWD) gets 12 around town and 15 on the hiway with no towing, and I expect 9-10 when towing at 55-60mph. We'll see how that goes. The Gray Wolf looks to be more aerodynamic on the front than most trailers (very sloped front of the smooth plastic, but still has the washboard alum sides). No idea what impact an suv or capped pu would have over an open bed truck in wind resistance.
The towing MPG isn't too big of a concern as if we tow it 400 miles a year I'd be surprised. Is all the other driving around that eats the gas.
Chris, Wills (16) Evie (13) & Toby our collie (6)
2011 Grey Wolf 28BH
2013 Chevy K1500 Crew w/ Reese StraitLine Dual Cam
Nights camped 2011: 11 2012: 18 2013: 12 2014: 12 2015: 13 2016: 56 2017: 8+
prof_fate is offline   Reply With Quote
Old 04-10-2011, 11:30 AM   #30
sherdep's Avatar
My Parents own a 2001 Dodge with the 5.9L 24 vavle cummins diesel and they towed a 5th wheel (I think it was 35 feet) and were averaging around 10 mpg - unloaded it was around 20mpg - of course my father drives like an old lady so that will make a diffrence in the way your driving style is also.
I know that the OP has a 2010 Diesel so he has the 6.1L and not the 5.9L Diesel.
EGT's (Exhaust Gas Temps) are what kill the diesel's so if it was me I would definatly get EGT Gauge installed so you know where you are at and if the temp's get up there it might be a well worth investment to go to a larger piped exhaust which will help the diesel breath.
