Old 09-17-2019, 10:54 PM   #1
Fueling Towing Vehicle
Getting in and out of fuel stops, gas, is getting more difficult it seems. Very hard to pull thru due to location of pumps and store, just not enough room. Any suggestions as to making this easier? Are some brand of fuel stops easier than others,
sadiemack is offline   Reply With Quote
Old 09-17-2019, 11:05 PM   #2
Have your navigator do a google satellite view of potential fuel stops. We usually plan our fuel stops way in advance and prepare ourselves by looking at potential gas stations with satellite views if we are new to an area. We often do that before we leave our camping spot or if we are currently at a gas stop and planning out next one.
2017 Coachmen 233RBS
2018 Ford F150 Lariat 3.5 Eco
"Common sense is not very common"
babock is offline   Reply With Quote
Old 09-18-2019, 01:23 AM   #3
rsdata's Avatar
Certainly the larger interstate gas stations, Pilot and Loves here in the mid-west and truck fuel sales ( truck stops) places have larger islands and more room to navigate. I stay wide away from the pump which allows me some room to navigate or even back out if I have to. Sometimes just be patient and let other cars in the way to move before trying to pull out. I have had to pass up stations that were too tight, or too busy and go another exit... so plan ahead before you get close to running out.
ďToo much of anything is bad, but too much good whiskey is barely enough.Ē Ė Mark Twain
2014 Shamrock 183
Old 09-18-2019, 04:44 AM   #4
frank4711's Avatar
Here in FL 90% of stations and all they are building are really big ... Ractrac WaWa circle K and in competition to see who can build the most stations ...14' clearance and 24-30 pumps and they are easy in and out .... when we travel Loves is our first choice then Pilot or Racetrac ... recent trip with my brother in law both of us pulling 32' 5th wheels we stopped same station with no problems ... Loves almost always have RV parking on the side so we can pull away from pumps and go inside ...
Frank & Cindy *** Rockwood Ultra Lite *** 2019 Ram *** Remi & Sage traveling Pomskies *** TST 507 TPMS *** B&W Patriot 18K *** 3.92 axle *** Goodyear Endurance *** 32 days camped 2019 *** Predator 3500
frank4711 is online now   Reply With Quote
Old 09-18-2019, 06:35 AM   #5
Native Texan's Avatar
I learned on our first trip bringing our trailer home to start looking for fuel at half a tank. From here on out I will pre-plan all fueling stops. Of course, if you have a diesel, truck stops make it easy....
2015 Flagstaff V-Lite 30WFKSS
2013 GMC Sierra 2500 HD Duramax
Native Texan is offline   Reply With Quote
Old 09-18-2019, 06:48 AM   #6
frank4711's Avatar
Yep ... we start looking with 75 miles left in tank ... Cindy just grabs the phone and starts calling off what's coming up .... easy on the interstate if we are on state roads we look sooner most of the time it means next town...
Old 09-18-2019, 06:58 AM   #7
Prime Member
One of the key reasons I upgraded to a diesel truck and can now fuel up in the truck lanes.
2016 Coachmen Freedom Express Liberty Edition 310BHDS
2013 Chevy Silverado 2500HD LTZ 6.6L V8 Duramax
Husky weight distribution hitch with sway control
Forever in my memory and in my heart. Laurie J. Wood 3/22/67 - 8/23/19
timfromma is offline   Reply With Quote
Old 09-18-2019, 07:10 AM   #8
As a last resort if the fuel tank is getting close to empty, you could always drop.the trailer and just take the truck to the pump. We did this once while traveling. Gas station was tight and crazy busy. I was able to pull in lot across the front. Dropped trailer got gas. Took an extra.20 mins but better than hitting something. I was.told.this solution by a fellow camper, not sure I would have thought to do this. He actually dropped his camper in a Wal Mart lot across from gas station. Again, just a thought.
Cabinfever97 is offline   Reply With Quote
Old 09-18-2019, 08:58 AM   #9
Jim34RL's Avatar
Do you have a gas engine or a diesel engine tow rig? For a diesel engine tow rig, which I have, I use a booklet called the NEXT EXIT also an RVER'S Friend. The NEXT EXIT cover's the interstate truck stops, with the RVER'S Friend covering the non-interstate highways. These stops are all listed by cities in the state you are traveling through.
For gas stations un-hook fill up and then re-hookup this will be the easiest way to fill a gas rig. In my humble opinion. This is why I stop towing with a gas engine rig back in 2007. Could not get in and out of gas stations with my small 5th wheel and truck!
Jim W.
2016 34RL CC; 2008 Ram Mega Cab 2500HD, 6.7L, 68RFE 6 speed, 4X4, Smarty S67, TDR 123K+miles
Old 09-18-2019, 09:32 AM   #10
frank4711's Avatar
I find the number of new "big" stations it is just not a problem ... my limited experience is FL GA TENN and SC ....
Old 09-18-2019, 10:09 AM   #11
Having diesel it is easier to get fuel. We are smaller than 18 wheelers.
Body damage from bumping anything costs a fortune to repair. We are beginners. Been lucky so far. Yes, I refuel anytime we drop the fiver.
The local credit union had their drive up system destroyed twice in a year.
Not so far fetched as one might think.
Most folks prefer to fuel their cars at the easiest pumps for rvís.
tomkatb is offline   Reply With Quote
Old 09-18-2019, 10:39 AM   #12
llr
Most stations have room to back out if you can't pull around, have someone spot you if you don't have a camera. I back out more then pull through.
I found it much harder to find station when I had a MH with a toad as you can't back up without disconnecting although the 75 gallon tanks helped
TT 2017 Flagstaff 831CLBSS Classic Ultra lite
TV 2014 Silverado 2500 HD
llr is offline   Reply With Quote
Old 09-18-2019, 06:20 PM   #13
Extra fuel......
Is my answer.
Depending on far were going I'll bring two 5 gal diesel cans and ratchet strap them in the bed of the truck. Then when we stop for lunch I'll dump them in. We do this if the 2 cans will take us to the campground without a gas station stop.
Greg in Michigan
Greg in michigan is offline   Reply With Quote
Old 09-18-2019, 06:54 PM   #14
Gold Tee Box
Teetime's Avatar
Great advise, with TV and TT, we are about 56ft. We look ahead at fuel stops in satellite view and make plans well in advance. If more stations had pumps parallel with the road it would be easier to get in and out of.
I am sure there are many threads in this forum about this subject.
Now that we have gone diesel, it's mostly pulling in with the big boys for fuel. There is a protocol to get along with the truckers, but we don't hold them up and get along fine.
While at a local Loves truck stop recently, there was a 2500 with a fifth wheel, and a Jeep as a toad, pulling into a gasser pump. I was really impressed that the guy could get in and out of there, so it can be done...
Success is hiring someone to mow your lawn so you can play golf for exercise.
2018 GMC 2500 Duramax Denali
2018 Coachman Freedom Express 287BHDS
42 campgrounds/292 nights since 2015
Teetime is offline   Reply With Quote
Old 09-18-2019, 07:04 PM   #15
Brake is on left
The Evil Twin's Avatar
I will hit a truck stop if I have to but man is their Diesel expensive. On the plus side, I can drop 40 gallons in half the time of a regular station thanks to the high volume pumps.
Most times, I just block whatever I need to block in order to make sure I can pull out. Most folks do not seem to mind much and just go out a different way. Those people that give me the stink eye can go on with their miserable little lives. I won't pull 62' of rig into a spot I am not sure I can get out of.
The Evil Twin is offline   Reply With Quote
Old 09-18-2019, 07:08 PM   #16
BandJCarm's Avatar
Trax3 extra tank, auto-magic filling.
Great stuff, Maynard.
FROG AR-0019-242
BandJCarm is offline   Reply With Quote
Old 09-18-2019, 07:25 PM   #17
tonyz1's Avatar
When towing on Interstate highways we too use the NEXT EXIT book. It shows RV friendly stations in red. Before we got that book, we would have to look up truck stops on the web, which is not always feasible when traveling in areas of low cell coverage. And we have learned to try to plan our stops ahead of time, before we get on the road, to lessen the stress a little. Guess I'm learning with age! Ha!
tonyz1 is offline   Reply With Quote
Old 09-18-2019, 07:44 PM   #18
W5CI's Avatar
if you are in Texas there is Buckee's, you could fuel a 747 at their fuel island
2005 Cedar Creek 30RLBS/TrailAir Hitch/ MORryde 7K IS/Disc Brakes/ PI PT-50 EMS/ RV Flex Armor Roof
2015 RAM 3500 DRW 6.7 Cummins 3.42/ Garmin 760RV
40 Gal TransferFlow fuel tank/ TST 507
Amateur Radio W5CI 2017 Days Camping 77
2018 Days Camping 44
W5CI is offline   Reply With Quote
Old 09-18-2019, 08:33 PM   #19
Lets go camping!
str8t six's Avatar
fueling with a trailer sucks. makes me want to get a 40 gal aux tank!
but i still whip my truck and trailer in a regular gas station, dont bother me none. ill block off half the parking lot if i have to get to the only diesel pump.
2014 Rockwood Mini Lite 2504s
2016 Ram 3500
str8t six is offline   Reply With Quote
Old 09-18-2019, 08:57 PM   #20
DavidBo's Avatar
If I'm needing gas and I'm in a town rather than the open road, I'll either use the good ol' Google Maps satellite view or just head down a main road and do a visual check of the gas stations available as I drive by, circling the block if I see a likely candidate. I concentrate on the ones at intersections because they often have the option of entering on one street and exiting out the other, avoiding any dreaded sharp turns.
Those at the edge of town are also better candidates as they tend to have more space, and big-box stores with pump stations in large parking lots are also likely to have more turning room.
DavidBo is offline   Reply With Quote
fuel, towing
