Old 05-04-2016, 07:24 AM   #1
Fullway termination valve???
What is this valve and how do I make sure it is open? This is on my new 323 MK Wildcat.
Name:	ImageUploadedByForest River Forums1462364630.737448.jpg
rogerkathy is offline   Reply With Quote
Old 05-04-2016, 07:51 AM   #2
arpipeliner's Avatar
I would think your black tank valve. Probably just another name for it.
arpipeliner is offline   Reply With Quote
Old 05-04-2016, 07:55 AM   #3
Flybob's Avatar
That is your black Tank drain valve. If not open it will pressurize black water storage system and cause something to fail.
2015 Freedom Express 248RBS
TST Tire Monitors
Honda 2000I + Companion
2 100W solar panels
Old 05-04-2016, 07:59 AM   #4
So how do I know if it is open or closed? And how do open or close it? Is this the rod I pull out to drain the tank?
Old 05-04-2016, 08:02 AM   #5
Yes. You need to have the tank drain open. I occasionally close it for a minute or two to get a little more water in the black tank, but I never walk away from it with the black tank valve closed.
2015 335DS
ScottBrownstein is offline   Reply With Quote
Old 05-04-2016, 08:02 AM   #6
Pickin' & Campin'
As said, the fullway termination valve is another name for the black tank 'blade type' drain valve.
The disclaimer is there to hopefully prevent you from flushing the black tank with the drain valve closed. Should you get sidetracked while flushing, the tank could fill, bust, squirt crap (literally) out the vent pipe on the roof, or leak inside around the toilet.
Days Camped: '15=22 '16=46 '17=30 '18=4
Old 05-04-2016, 08:03 AM   #7
clr
A fullway termination valve is a gate valve by its proper RV name. So they are saying that the black tank dump valve must be open during the use of the black tank flush system. This is so you do not have sewage blowing out the vent on the top of your RV, breaking the black tank or coming up through the toilet. All things that you never want to happen. People tend to forget that the water in the flush system is running that is the reason for the warning.
Chuck & Sandra
Engineer/Teacher
2010 F350 CC 6.4
2015 Prime Time Sanibel 3601
clr is offline   Reply With Quote
Old 05-04-2016, 08:04 AM   #8
Usually Confused Member
emm-dee's Avatar
It's also know as the flux capacitor.
Took me a while to find out (from the forum) what they were talking about when the printed that sticker. Doing a google search only brings up references to it on RV forums and sites...nowhere else. I would have been a lot simpler to just say black tank drain valve, but I guess some college boy that just got hired was trying to impress someone.
If left closed while flushing the tank won't pressurize and the only bad thing that will happen is the tank would overflow into the camper...probably come up through the open tube toilet.
After draining and flushing I always close the valve and let water run into the tank for about two minutes. Since I started following other members suggestions here I put water softener and a dash of pinesol in the tank. Having that 3-4 gallons allows complete dilution and also keeps it sloshing around as I drive down the road.
At some point during every day you suddenly realize nothing else productive is going to happen the rest of that day. For me, it usually occurs around 9 am.
Vengeance 25V (the Harley needed a home)
Old 05-04-2016, 08:06 AM   #9
Pickin' & Campin'
Like Scott said, it's OK to close the valve for a minute (while flushing) to allow a LITTLE water build up in the tank for a better flush of the tank. DO NOT walk away when flushing with the valve closed.
Didn't your dealer discuss the flushing procedures with you during your PDI?
Old 05-04-2016, 08:30 AM   #10
I really LOVE this forum!!! Quick responses! Much better than internet searches! I have found that there is so much nowadays for dealers to discuss with buyers that, because they are human, they don't remember everything. However, I do know I can rely on this forum to provide the answers and support I need to help me out. Even though I am an experienced camper (starting out with 2 man tents, dry camping, hauling my gear in canoes and camping on riverbanks, then working through bigger and bigger tents and ending with my 3rd bigger trailer) I find there is still a lot I don't know. Thanks for all your help!
