Old 09-19-2015, 10:32 PM   #11
It's a square black one.
2015 Grey Wolf 27RR Limited
2011 Dodge Ram 1500 5.7L Hemi
2011 H-D Ultra Classic
BKM1066 is offline   Reply With Quote
Old 09-20-2015, 07:19 AM   #12
Head Rambler
Does any numbers show up if you press the + or - buttons?
Gotta go campin!
Old 09-20-2015, 03:20 PM   #13
No numbers at all.
Old 09-20-2015, 04:07 PM   #14
DaveSchwartz's Avatar
Does anything else 12 volt work? Sounds like no power to the thermostat. Is your battery disconnect passing power?
2015 Rockwood Signature UltraLite 8282WS Platinum, GY Marathon LRD, TST 507RV TPMS
2005 GMC 2500HD CCSB D/A, Curt E16, Prodigy P2, Garmin RV760LMT w/BC-20 b/u cam
Self restraint is for the young. I'm old and want it NOW!
DaveSchwartz is offline   Reply With Quote
Old 09-20-2015, 06:14 PM   #15
Head Rambler
If you don't see anything on the display, then it's either a bad or not getting power. If you're comfortable checking voltage you can remove the front of the t-stat and see if there's 12 volts on the power wire.
Gotta go campin!
Old 09-20-2015, 08:47 PM   #16
Originally Posted by BKM1066 View Post
New to camping, gave a Grey Wolf 27RR, how do I run furnace while on battery power? I have the Domestic thermostat, it won't power up so I can run furnace.
If tt is not plugged in to 110 volts house power the battery may not have enough power to run the furnace 9.5 volts DC min to run furnace. furnace needs a good full charged battery to operate. The furnace is a 12 volt power hog and will drain a battery very fast.
TimVWulp is offline   Reply With Quote
Old 09-20-2015, 09:19 PM   #17
Found this out the hard way. Apparently something tripped the converter breaker and my battery drained. Flipped the breaker and good to go .
Jim
Krawler is offline   Reply With Quote
battery, furnace
