Old 09-19-2015, 01:07 PM   #1
Furnace operation on battery
New to camping, gave a Grey Wolf 27RR, how do I run furnace while on battery power? I have the Domestic thermostat, it won't power up so I can run furnace.
BKM1066 is offline   Reply With Quote
Old 09-19-2015, 01:28 PM   #2
Pod2Vibe's Avatar
Sounds like a fuse, since the furnace is 12VDC.
Do you have the digital thermostat?
Any lights on it?
Pod2Vibe
2015 Solera MBS 24R - Hellwig/Sumo Equipped
TOAD: 2014 Fiat 500 Abarth
(Sold the Vibe 6506)
Pod2Vibe is offline   Reply With Quote
Old 09-19-2015, 01:30 PM   #3
Try running something else with propane like a range couple minutes, it helps clean air from lines. Then try furnace again. Be sure battery is providing power to other DC items to verify that also.
Dobe Fanatic - Largo, Florida
2012 Flagstaff T12RB A-Frame
DobeFanatic is offline   Reply With Quote
Old 09-19-2015, 05:21 PM   #4
The digit thermostat doesn't turn on at all.
2015 Grey Wolf 27RR Limited
2011 Dodge Ram 1500 5.7L Hemi
2011 H-D Ultra Classic
Old 09-19-2015, 05:30 PM   #5
Running water heater and fridge of of propane. Other lights and water pump working. The fuses on the panel under fridge all look good.
Old 09-19-2015, 05:32 PM   #6
If you have a brown cover on the furnace take it off and see if you have a breaker under it.
Ontario
Vibe 6501
1 Prospector Canoe
2 Mtn. Bikes
4 Hiking Boots
Happy Vibe is offline   Reply With Quote
Old 09-19-2015, 05:42 PM   #7
Head Rambler
Can you post a picture of the t-stat?
Is it the factory t-stat or an upgrade?
If it's an upgraded model check the batteries in the t-stat itself.
Gotta go campin!
Old 09-19-2015, 05:56 PM   #8
As far as I know it is the factory stock t stat.
Old 09-19-2015, 06:17 PM   #9
Head Rambler
Is it the square one or rectangular one?
What color is it?
Do any numbers show up on it if you press the buttons?
Gotta go campin!
Old 09-19-2015, 08:08 PM   #10
If you still can't get it to work, try this website.
I have a Dometic digital thermostat that operates a single
2007 Surveyor SV230
- 200 Watts Solar/MPPT Controller - 230 AH Battery Bank - 600 watt PSW Inverter - (2) 2000 watt Inverter Generators - LED Lighting
Boon Docking 99% of the time.
2009 F150 - 5.4 Litre - Tow Package
boondocking is offline   Reply With Quote
battery, furnace
