Old 12-28-2015, 07:28 AM   #11
Blog: RVroadtripper.com
hbillsmith's Avatar
Originally Posted by Mr Havercamp View Post
Maybe your correct however $399 ( $320 with the discount you mention) is a hefty chunk of change for the 12 that clearly is a piece of junk. $499 ($399 discounted) is even heftier for the 48 that supposedly works although I have not read many great reviews for it. Your original camera apparently came "with" your unit and when it was found to be junk Furrion/LCI appeased you by giving you the upgrade. Would you have purchased this stuff at those prices if you would have been in the situation that most are where all you get is a mounting bracket? Search around and you'll find all the posts about the Furrion TV's and how they fail. I installed the Furrion 30 amp power connector on my last trailer and within a year the entire assembly had deteriorated from UV to the point it fell apart. I couldnt get so much as a response from Furrion so that tells me their warranty is not worth the paper its printed on.
Sorry to hear that your Furrion experience was so bad. Just a brief follow-up on mine.
The model 12 camera was not found to be junk. In fact it worked perfectly fine as a backup camera but did not function well as a pseudo rear view observation camera. I was wanting to use my camera while in motion towing down the highway. For that purpose it did not do well. In particular, screen dropouts and freezes. I called Furrion and was immediately transferred to a tech that explained that model 12 system monitor is designed to support 2 cameras and it's processor is optimized for a multi-threaded, though semi-stationary, operation.
He explained what I was looking for was the model 48 which has a more powerful processor and is single threaded. I offered to pay the difference for the upgrade and he said never mind, they would just exchange it. 2 days later, UPS showed up with a brand new camera and a pre-paid return slip for me to ship back the model 12.
One more thing, I had a cheap Amazon rear view camera (less than $100) I bought for my 2012 travel trailer. It was a wired version that didn't have any wireless issues and the monitor and quality were terrible. When I got the Furrions I expected them to be just as bad. They weren't. The model 48 is very clear whether it's night or day.
Again, I am very sorry your experience was different than mine.
Maxxis 235/80/16E; AirBags w/AirLift 1 wireless compr; 4-Fold Tonneau; 6000# Dexters; mor/Ryde Rubber Pinbox & CRE3000 w/HD Wetbolts; Andersen UltimateII Aluminum 5erhitch on Reese Flipball w/Curt 4" offset ball; LCI Ground Control3 4pt+2pt Elec.Rear stabilizers; 3 Slidecovers; King Dishtailgater; 10ft. Portabote w/5hp Outboard; Dual A/C; Furrion48 Rearcam; Champion 3100 Inverter w/DIY Extended Run
hbillsmith is offline   Reply With Quote
Old 12-28-2015, 07:57 AM   #12
Fair enough. Glad you like their products. My experience with Furrion, and many other peoples bad experiences I have read about not only in this forum, but in many others, tells me to avoid them if it all possible.
Good luck.
Mr Havercamp is offline   Reply With Quote
Old 01-02-2016, 09:10 PM   #13
rogo's Avatar
I, too, have read the many negative reviews about the Furrion camera. In most cases, I suspect the reviewer has tried to use the cheaper FRC12TA-BL model (a backup camera) for something other than its intended purpose. The 12 model is for seeing what's behind you as you back your RV at slow speed like when you're backing into your campsite. It is NOT for seeing behind you at highway speeds.
The FOS48TA-BL model works quite nicely as my "rear view mirror" at highway speeds. I've experienced no lag, no dropouts. The picture is crisp, the refresh rate is real-time, the wide angle color image is just right. I installed mine in minutes in the pre-wired mounting bracket on my 35' trailer. Rather than mount the monitor using the supplied suction cup thingy (and taking up additional windshield real estate,) I chose to simply attach the monitor to the face of my rear view mirror with a couple of elastic bands. Takes just seconds, and puts the information right where I expect to find it.
Admittedly, I've only driven about a hundred miles with it, but it's been an overall positive experience for me. I expect easier parking and safer driving. I bought mine online for $400.
Roger, Sherrill, and Harley (Great Dane)
2016 Flagstaff V-Lite 30WRLIKS [sold]
2012 F-150 XLT Screw 3.5L EB, 3.55
Air Lift AirCells, Blue Ox BX1500
rogo is offline   Reply With Quote
Old 01-02-2016, 09:40 PM   #14
B and B's Avatar
I won one at the Goshen rally in 2014, it did not work correctly. They sent me another NC. Worked better as backup camera. At Goshen in 2015 I asked and was supplied with the 48 model, works great! No complaints at all.
2017 Heartland Bighorn 3575 Elite with Reese Sidewinder
2016 Ford F 350 SD PS 6.7 SRW Crew Pucks and Reese 18 K Elite
2013 Rockwood 8289WS 2012 Rockwood 2703 SS TT 2007 Golden Falcon 38FLA PM 1983 Corsair 21RB
2015 Ford F250 PS '13 F150 3.5 Eco '09 F150 5.4 l 1987 Merc Grand Marq 1982 Ford E250 CW
Old 01-02-2016, 10:20 PM   #15
Usually Confused Member
emm-dee's Avatar
YMMV. The Furrion is plagued by the same problems affecting most other wireless systems...interference occurring between the camera and the monitor. In my attempts to use the Furrion (the -48 model) I could get a pretty good picture..actually an excellent picture, whenever the truck was turned left/right to about the max limit. But, when driving straight ahead the view on the monitor was like looking at a '50s era Admiral TV (only the ole timers here remember those). The problem is the camera is needed the most when driving straight down the highway. I could take the monitor out of the truck and move 6-10 feet left or right and the picture would suddenly be perfect.
Tried an install on a neighbors 35 (maybe 37 or 38, don't remember) foot Keystone 5er. Better results (go figure??) with the bigger unit but still not an acceptable picture. Then, I saw the same unit on a 40 foot Heartland and it was a perfect display. ?????
The problem is the interference between the camera and monitor which will vary greatly between units. I'm beginning to think the location of the microwave or refrigerator is a factor. The Heartland had a center cabinet with sink, etc., and we joked that the signal was pinging off that to get to the truck.
I installed a wired system on my horse trailer but looks aren't that important in the horse area (can see the wires running down the corner). After that, the wires are under the trailer and completely bypass the living quarters area. It requires an additional connection when hooking up to the truck but the display in the cab is beautiful. Can see views of the road on the right side and behind the trailer plus forward and aft views of the horses during travel (gotta keep an eye on them...they are worth a whole lot more than the entire truck and trailer combo).
Unfortunately, running wires through my TT was not an option. I really didn't want to see wires on the wall or ceiling and getting them hidden would have required removing a lot of the interior panels. That's way too much work for me and my limited skills. I finally installed the Sharx system because I'd had really good luck with that at my home (four wireless cameras). It connects via wifi to a router in the front of the trailer (about 25 feet) which allows connection to an iPad (about 15 feet). And, the rear camera has an sd card that records the last 7-8 hours of everything the camera sees. Interference is not a problem because of the short distances in use.
At some point during every day you suddenly realize nothing else productive is going to happen the rest of that day. For me, it usually occurs around 9 am.
Vengeance 25V (the Harley needed a home)
Old 01-08-2016, 09:36 PM   #16
justpassinthru's Avatar
Check out www.tadibrothers.com. Just installed mine. Works great and quality is there.. A little pricey but you get what you pay for
Jim and Ruby
justpassinthru is offline   Reply With Quote
